FTI triple disc converter questions
I put a 2800 stall 9.5 inch triple disc FTI in my Silverados 6L80 back in Feb of this year. Noticed fluid coming out of the inspection cover recently. I test fit it before reinstalling the trans. It seemed to engage the pilot hole in crank and was flat against flexplate. But Im wondering if I shouldve used the spacer that comes with it? Anyone else had this happen? Its either the converter leaking, bad new fluid seal or converter isnt engaged all the way. Just wondering if anyone else has experienced this. I build transmissions for GM and never had a fluid seal leak thats new, esp on a 6L. But I know anything is possible. Gonna take it out next weekend and look. Hoping someone with a FTI or Circle D can help! thanks.
Did you measure the endplay between the converter and flexplate? Should be 3/8", that is what the shims are for as it allows for growth when things get hot. Did you lube the converter snout inside and out so it didn't tear the o-rings in the trans?
Yes to both. I put trans gel on the converter and turbine shaft seal. I had put fresh fluid on the o-rings. the gap looked right before I bolted it up. Looked like the stock converter gap. I also set it up on the flex plate before installing. It was flush on the flexplate and the hub looked to be in the pilot hole of crank. Im hoping its just a bad new fluid seal. But I have read that FTI has had some issues with their welds lately, so who knows. Bout ready to just put a ZL1 converter in it again and say heck with it. lol
We recently installed a FTI 9.5" Triple Disc 3600 in my sons 2010 Camaro SS with the 6L90 trans. We had to use the spacer / adaptor that came with the converter as the snout on the converter was smaller OD than the ID of crankshaft. We had just over 1/8" endplay between converter and flexplate. Lately I've seen several people say they must have 3/8" but FTI, BTE, and Circle Ds instructions all say 1/8'' to 3/16'' ???
As long as its not leaking Id say youre good. Im going to take mine out this weekend and check the seal. If thats not leaking and the welds are good on the converter, Im gonna put the spacer on and see if that cures it. It doesnt leak alot, like blowing all over the bottom of the truck etc. just a few drips here and there. Thats what is so puzzling.
This may be of help? When we swapped our converter, I laid a straight edge across the face of the bellhousing and measured. The stock ZL1 converter pushed all the way in the pump measured 1/4'' from the snout of the converter to the straight edge and 1'' from the straight edge to the pad that bolts to the flexplate. The FTI converter measured exactly the same.
Well an update. Took trans out Saturday and found a leaking front Torque converter fluid seal. Output shaft seal was leaking too, but I didnt replace that when I rebuilt the trans. Ive built thousands of these and never seen that seal leak, but who knows with GMs quality these days. Anyways, I didnt see anything jumping out at me on why that would be leaking. But out of caution, I put my old ZL1 converter back in. no leaks now, and drives fine. Acceleration is much slower though lol. Im wondering if that adapter or spacer just needs to be in there to keep converter all the way in to trans. Makes sense, but my measurements when I installed it where right were they want them, without the spacer. I almost wanna put it back in with it and see what happens now.
