Results 1 to 3 of 3
Thread: 15 mustang p1sc fuel settings assistance requested
    Jul 2025
    just finished installing the p1sc and im trying to get it running before i install the id1050s. car was on sct before so i no longer have a base tune for the gt350throttle body. i installed twin dw400 pumps dead head return style with an aeromotive regulator set at 43psi. i changed the infered hi and low to 43.5 psi but im missing something. anyone able to take a look and help a guy out?
    Jul 2025
    update, i bumped my base fp up tp 55 and flahed that in aswell. it started and would run after some massaging of the pedal but it did stall at idle.
    Oct 2016
    Poland
    2,042
    You choose 43psi yet injector data starts at 50. All of them should run on at least 58 psi aka 4 bar.
    You run a stock MAF as your tune seems to have stock MAF? If you are using GT350 TB you should get GT350 data in tune, wont run properly on stock model
