Results 1 to 2 of 2
Thread: Help Removing AFM, TM and Improving Shift
    Apr 2025
    30
    2010 Camaro SS L99 6L80
    I think I have the TM removed/decreased. I'm not looking to do a complete delete.
    Also want to make sure I did all values to delete the DOD/AFM.
    I slightly increased the shift pressures and change the time some while also taking the torque convert to only lock up in 5th.
    Would like to add a good bit of timing but have not played with VVT before. I'll log in the morning.
    L99 DOD FILE.hpt
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    954
    Shift Pressure and Scheduling
    This worked really good in my 2011,You can compare to yours and see.
    Full disclosureIt was copied from a CTSV, I might have made some minor changes.. Obviously you will leave your torque converter stuff, but this is good quick firm shifts.
