Send me vehicle info and I?ll help ya get the base file
also tried all options suggested only get to 7% then fails to read, just have to wait for the fix i guess
Send me the cal you using and I?ll help get a cal
Its the chassis issue, reads fine on a bench. Some of them read only virtual like 21-23 F150 used to.
v-performance.pl/
facebook.com/veee.performance/
https://www.instagram.com/v.performance.pl/
Remote tuning(don't work for free!):
[email protected]
+48 697276579
What about RR3A-14C204-BBB
24 Mustang GT
I have not been able to get it to read or virtually read.
I am using a MPVI3
Here you go?.
Awesome!
I appreciate it.
Hey guys,
We're working on fixing this ASAP, fingers crossed we can sort it out first thing this morning. We confirmed the reading worked on a few cars but apparently there's something specific to the S650 chassis (presumably something with the gateway module) that's breaking the non-virtual read. As Vee already said, bench reads work fine and a gateway bypass would also probably work fine.
Virtual read should be fully functional unless we don't have the calibration in our database. We're adding things as we go. Thank you guys for your patience while we sort this out![]()
so all the ones that are advertised on fb & the likes how were they read in or out of the car?
99% of them are going to be virtual reads. We didnt want to competely pull back the non-virtual read because its working correctly on every other platform we released on Friday.
A few people have done bench reads as well
Any update on whipple cal S650
Also the roush base would be mint!
S650 reading should be working as of VCM Suite 5.1.4626. We've confirmed on three cars at this point, but you may need to retry multiple times before it works
All you guys asking for Whipple/Roush support. Give me time to get those defined.
Eric Brooks
HP Tuners, LLC
Hey guys! Thanks for all the debug work, it's truly appreciated.
I just ran 5.1.4628 beta on my 2025 GT PP, and it hung while I tried to 'Read Entire'. It tried a few times, but never past 1%; I had to use Task Manager to shut down VCM Editor.
On Virtual Read, I got request to turn off, wait, then on, then it failed again.
I assume you guys are banging away, so I'll chill for a few more hours to see if newer Beta versions arrive.
So close!!
Looking forward to it. Thanks for the updates!
