I'm adding a turbo and want to tune in the VE mode and eliminate the MAF. Truck ran fine with the MAF plugged in. Now it won't start at all after removing MAF. Tries to fire occasionally, but really just cranks over.
I've added a IAT sensor and deleted the stock MAF.
Added my 2 bar sensor and updated the file to support the right tables.
Extrapolated the data from 105-210 to fill in the new VE table.
MAP sensor has the right calibration.
Write all to the truck for the new changes.
I've made all the necessary changes in the tune to put it into VE mode (ie change the Dx MAF fail, make sure all the settings disable the MAF,
I just don't know what to change in which direction to start. I've swung it both up and down 5-25% in the VE table with no change. Any advise on where to begin to get it to fire up would be great.
Its a 2003 4.8L from a Tahoe swapped into a 1954 International truck.
Mods: Ported 243s, Sloppy stage II cam, headers to turbo, WB
Current file attached. 54International 2 bar turbo VE tune.hpt
