Results 1 to 9 of 9
Thread: Manual shifter mode how to stop it jumping down gears when i 100% throttle
    Jun 2025
    14
    hi all , when i move my shifter over to manual mode i dont want the transmission to change down gears. if im in 4th at 3000rpm and put the foot to the floor i want it to stay in 4th gear.. same goes for all the gears.
    what do i have to change to make this work?
    2022 jeep gladiator rubicon 3.6 with magnuson supercharger zf8hp2 transmission.
    JEEP 8HP - edit 2.hpt
    thanks
    Aug 2021
    Indianapolis Area
    467
    Log and watch "shift ID".
    In case shift ID 27, change table 44111 (Trans -> Shift Scheduling -> Shift Pattern -> On the right side of the table - downshift side, change to a lower value - as it fits to your needs). Example of value in the image attached.
    If you need further support, send me an email
    DodgeBoy.
    Email / Remote Tune: [email protected]
    Jun 2025
    14
    Yes , shift ID in manual mode is table 28 , what figures do I have to put into downshift area to totally prevent the down shifts please
    Aug 2021
    Indianapolis Area
    467
    Quote Originally Posted by Gladus View Post
    If you want to avoid completely, change the downshift side (right side) to zero
    DodgeBoy.
    Jun 2025
    14
    Thanks I’ll give it a go
    Jun 2025
    14
    I did what you recommended but still downshifts in manual mode ? Any more suggestions
    Aug 2021
    Indianapolis Area
    467
    Do you have a log?
    Is it downshifting once throttle is pressed or to not stall the engine?
    DodgeBoy.
    Jun 2025
    14
    I will get a log . It’s downshifting when I move shifter over to manual mode in any gear then when I put the accelerator pedal down 90-100% full throttle at low to mid rpms . What I did notice after the settings it won’t let me manually downshift pushing the shifter forwards
    852
    You're changing the wrong table.
