Results 1 to 19 of 19
Thread: 4.8 vortec hard start/long crank
    Jul 2025
    7
    I have a 4.8 LS with a cheap cold air intake and headers that has a hard time starting; most of the time, I have to make a second attempt for it to start. I was wondering if someone could tell me how off my tune is, or if they have any ideas on what it could be. I am far from a tuner, so I have no clue what I'm looking at. A friend gave me this, no clue how bad it is. fuel pressure is 58psi after prime and while cranking
    2,859
    And log of startup.
    Indiana
    465
    Tune looks stock when you compare to the same OS. MAF clocked wrong in that cheap cold air intake and skewing fueling maybe or a mechanical issue...needs a log as mentinoed earlier.
    "It'd be a lot cooler if you did."
    North Carolina
    4,929
    You mods wouldn't require any tuning changes to make it start up. I'll bet it isn't building and holding fuel pressure at start up or you have a cam sensor issue popping up.
    2,859
    Quote Originally Posted by Triton View Post
    What do you mean "a friend gave me this". Is this the file currently in the car? Did you load a random file into the car? Did someone try to make a "starter tune" with your original tune?
    Jul 2025
    7
    4.8 ls cold start log
    This is my log from this morning regarding a cold start. It took a couple of attempts, and it took a long time to settle into idle. I didn?t have an ECU, so my friend gave me one that he said was for a 4.8/4L60E. I also have a question that I?ve heard varying opinions on: is fuel pressure bleed-back bad? From what I?ve observed, that could be my issue. However, I?ve also heard that if you have 53-60 psi of fuel pressure before startup, it doesn?t matter if it bleeds back. The fuel pump I?m using is a Walbro electric in-tank fuel pump, which is just one I had on my shelf. I know it?s a big pump, and I?ve heard of this model having a weak check valve.
    2,859
    So, this is a swap of some sort? Need a lot more information about the setup if it is.
    Jul 2025
    7
    Yes, this is a swap. It's a 2001 4.8 Vortec out of a Silverado 1500, and I put it into a 1977 Dodge W200. It's a 4.8 LS, 4L60E, and a Dana 300 transfer case with a VSS generator and a Dakota Digital SGI-100BT. Everything is stock on the motor except for the eBay headers and cold air intake. The fuel system is the Walbro F90000267 with the stock return regulator at the fuel rail. Also, if this helps any, it will start right after you turn it off but will have a hard start if you try to restart it 5 minutes later, rather than instantly.
    2,859
    But you don't know if everything (sensor/injectors) that is stock to the motor is stock to the ECM. But first put a fuel gauge to it.
    Arizona
    1,324
    Yes, this is a swap..
    here is a generic list of things that help us help you.
    Vehicle make/model/year
    Tune AND data log
    Engine/size
    Axle gear ratio / tire size
    Computer and operating system used
    Type of heads (317/243)
    Transmission
    Torque convertor stall
    intake manifold
    Intake tube / air filter
    MAP part number
    MAF part number
    Injector part number
    cam used (link to specs)
    exhaust type (long tube headers, no cats, straight piped)
    pictures of engine
    pistons
    compression
    throttle body type, size and DBW/DBC
    Fuel pressure at idle and while driving
    fuel system type, FPR, pump size, returnless or no
    ect ect
    Jul 2025
    7
    **2001 Chevy Silverado 1500 Specifications:**
    - Engine: 4.8L LS
    - Gearing: 4.11 gears with 33-inch tall tires
    - OEM ECU: P01
    - Cylinder Heads: 862 heads
    - Transmission: 4L60E 4x4 with Dana 300
    - Stall Converter: Stock, 1800-2000 RPM
    - Intake: Stock Vortec intake
    - Air Intake: Cheap eBay cold air intake
    - MAP Sensor: 09359409
    - MAF Sensor: 25168491
    - Injector Part Number: 902-157-K8
    - Camshaft: Stock camshaft
    - Exhaust: eBay shorty headers with true dual exhaust
    - Pistons: Stock pistons
    - Compression Numbers: I don't remember all the specifics, but they were all good.
    - Throttle Body: Stock Vortec throttle body (DBC)
    - Working on getting a fuel pressure gauge.
    2,859
    Only place I see that injector number is partsgeek.com so who knows what you have there.
    Jul 2025
    7
    Yes, I bought them through PartsGeek as OEM replacements, but I couldn't find exactly what they were. I was hoping they would be close to OEM specifications. As a side note, I’m not sure if this helps anyone, but the truck runs and drives great; my only issue is with the start-up, and the 1-2 shift is quite hard.
    Nov 2018
    Middle TN
    99
    Is the throttle blade screw opening the blade? The vacuum signal is low for a stock deal and it's moving twice the amount of air across the MAF as it should. Make sure it's shut, doesn't have holes drilled in it, also look at the IAC and make sure the pintle is still attached.
    Jul 2025
    7
    I checked the IAC and the throttle body, and both are in good condition. I also tried replacing the IAC with a working one, but there was no change. Additionally, I performed a fuel pressure check, and it consistently reads 55-60 psi before crank, during cranking, at idle, and under load.
    2,859
    Your injectors may be close on "flow rate" but could be off for some of the low flow characteristics. But if it idles and is smooth at low throttle openings once started, injectors probably aren't where I would go next. Probably need to check on cam sensor reading.
    Jul 2025
    7
    I've also read a couple of things about cam position. I'm not sure if it's the same thing, but in the log I included, the readings were Cam Signal Hi to Lo and Cam Signal Lo to Hi. However, I'm uncertain about what they should indicate.
    Nov 2018
    Middle TN
    99
    So did you find the issue?
    Feb 2024
    395
    If you haven't figured it out already, check bank 1 for vacuum leaks, misfire, exhaust leak near the B1 O2 sensor, it didn't run long enough to enter closed loop but your bank 1 STFT is adding a ton of fuel, around 20% for most of the log, and bank 2 STFT is within a couple percent of 0.
