I normally use the serial input on my Innovate wideband for my PE tuning, but since I also have the analog input option, I decided to compare them. On my channel list, Innovate sp is the serial input, and MPVI. 2 is the analog input. You will notice they do not exactly track each other, and the difference is not always in the same direction. I am curious if this is a difference in the actual wideband output or a difference in the polling intervals HPT uses for them. Ignore the slow narrowband switching and the transient issues I have not fully cleaned up yet.
