4 bar map sensor
I would like to install a 4 bar map sensor but I don't understand where and what to change the values to. Can someone help.vwgtistage293afradjustrev2.hpt I would like to do some testing with my 2016 vw gti.
MAP sensor or PUT sensor? I don't have the software in front of me, but I believe they are in the Airflow -> Turbocharger tab. Scaling for both MAP and PUT.
ECM 31403 is the MAP sensor and ECM 31404 is the PUT sensor
what values do you enter. in put and map for 4 bar Bosch sensor
Those values should come from the supplier of your sensors typically.
