Results 1 to 10 of 10
Thread: e38 Tach output RPMs too high (LS3 swap)
    Jul 2025
    10
    2013 Camaro LS3/TR6060 swap.
    Running tach output from pin 48 with a resistor pickup for the signal. I get signal, but it reads too high. I had high and low resolution set at 6, but it was reading approximately 2x what it should have been. I then read that 6 is for 4 cylinder and 3 is for 8 cylinder so I changed to 3 but now it's approximately 4x what it should be, so maybe I went the wrong direction?
    Screenshot attached, any guidance appreciated!
    Australia
    2,059
    they output usually suit 4cyl standard even tho its an 8cyl, just change the tacho to 4cyl will fix it if u cant change the output to 8cyl, if stock is 6 for 4cyl then try 12 for 8 cyl
    Jul 2025
    10
    To clarify, you are saying to do one of the following:
    1) change to 4 cylinder and run 6/6
    Or
    2) leave at 8 cylinder and try 12/12
    Am I understanding correctly?
    Thank you!
    Australia
    2,059
    was just thinking if 3 is 4x what it should be then see if 12 suits, i havnt played with that before so just a guess on my part
    Your tach output needs to match the tachometer you are trying to match. What engine did the vehicle originally have? Also gen 3 and gen 4 calibrations had different values for tachometer output. It?s based on the number of teeth on the crank reluctor.
    Jul 2025
    10
    It?s a Jaguar XJ6, so 6 cylinder. Engine is LS3 gen 4 so I assume 58 teeth.
    I could be wrong. I?m not at a computer to look at a tune. But, your 58 tooth reluctor is actually 60 with two teeth missing. 60 teeth divided by 6 cylinders (60/6) is 10. I think 10 is your magic number for tach output.
    Jul 2025
    10
    Quote Originally Posted by pdsq98gt View Post
    So would that be 10/10 HiRes/LoRes? I found one thread that said 9/10 for 6 cylinder, and the linear math of 12/12 is in a similar ballpark, so sounds like we're getting close.
    Do I need to manually change the number of cylinders in the top left of the screenshot, or do I only adjust the resolutions?
    Thank you very much!
    BR
    2,856
    How long would it take to try all of the combinations till you get one to work. And you can probably find a pattern and narrow it down pretty quickly,
    Jul 2025
    10
    Sounds like that?s the path forward. Thank you all for the help!
