i have a question ? does the pcm use the temp sensor to read the temp and if its to high and it sees the knock sensor voltage is at its normal range could the temp reading a temp that is lil high like 200 -205 and the knock is up at those temps could it set a low voltage for that temp and the range of the knock sensor, cause my temp on the scanner does run like 204 but on my mechanical gauge its like 180 to 185. not reading the same as the scanner, i didnt think much about it but was just thinking if the pcm thinks its running warmer than it is and the knock is picking up signals at the wrong temp could the temp sensor be off like 10 -15 degrees warmer causing the knock to set codes.
