Hello I'm new to Hptuners and i have a 2006 dodge charger 5.7 and i been trying to get pops and crackles but i just seem not able to get it the rpms will sometimes get stuck and will start slowly accelerating on its own it has long tube headers CAI but stock if anyone can help me out i would really appreciate it
Down below is my stock tune Thank you
Yes, hello,
But why don’t you try out the search function in this forum?
It’s for free and you can learn a lot of things.
I’m sure your question is asked before.
Thanks for the reply I?ve actually been using the search function quite a bit and while it?s helpful some of the info is outdated or doesn?t apply directly to my setup and it always a different year of vehicle which i need is 2006-2009
There are some YouTube videos out there. You basically have to put negative timing in the lower RPM ranges and add some extra fuel. You also need to change the temperature in the DFC fuel cutoff Don't hold me responsible, do some research, this is only a suggestion..hectors 06 charger 5.7 STOCKpopBang.hpt
