I went out and worked on the tps/iac. I ended up slotting it as it went down to .37v. I locked it down at .47. I worked on the raf and some blade adjustments. The air flow desired went nuts. This log was on my way home. The truck kept going lean in closed loop. I had to fight it home. That when I noticed on the log the idle desired shot through the roof.
This isnt the first time the truck stalled out or went lean. There are some demons in this truck.
7 21 25 truck idle desired raf went nuts.hpl
