Results 1 to 7 of 7
Thread: Replacing the GMPP ECU with a Production E67 for a/c Control.
    Feb 2017
    3
    I have an FJ80 that I put a GMPP 6.0 with a 4L80 into. At the time of install I did not realize that the A/C request was not just an input into the ECU. It seams that this is much more complex in terms of a/c request and output to compressor relay. I installed a pressure switch and the RPM Extreme a/c request module only to find out that the GMPP does not support a/c control at all. So the question is, is there a factory calibration to use with a production E67 ECU that would be a direct drop in to work with the GMPP harness and supporting parts. Being that the MAF and the ACC Pedal are what would typically be found on a truck engine I'm not sure what base calibration will work with this GMPP set up. The issue that I am wanting to fix is the drop in idle and occasional stalling when the a/c compressor cycles. Thanks in advance.
    North Carolina
    4,939
    late Trailblazer SS's were E67's. They have a hard wired cruise control too. I've never tried it.
    Feb 2017
    3
    So it's been 4 years since this install, I searched through my emails and found a reply to my GMPP parts rep. I forgot that we had discussed this and I actually have a Trailblazer SS ECU here that I ordered back then. I think that wiring wise that was the closest match. The issue from what I remember is that the Trailblazer SS does not have VVT and the 6.0 that I have does. Does anyone know if this is something that can be activated with HP Tuners? I would guess that it's more common to disable this feature then activate it.
    Jul 2019
    Shuswap, BC, Canada
    82
    Quote Originally Posted by TunedIn View Post
    So I don't KNOW the answer, but I took a few minutes to poke around.
    The TBSS tunes in the repository do have the Variable Camshaft tables in Engine -> Airflow -> Variable Camshaft.
    I also found a pinout that shows the CMP controls exist on X2:14 and X2:15 (Intake) and X2:50 and X251 (Exhaust):
    14 PK/BK 6395 Camshaft Position (CMP) Actuator Solenoid -- Intake Bank 1 Control
    15 TN/BK 6397 Camshaft Position (CMP) Actuator Solenoid -- Intake Bank 2 Control
    50 WH/BK 6396 Camshaft Position (CMP) Actuator Solenoid -- Exhaust Bank 1 Control
    51 GY/BK 6394 Camshaft Position (CMP) Actuator Solenoid -- Exhaust Bank 2 Control
    So from my point of view there is a good possibility it'll do the job.. but I can't say that with any certainty. It could be that the tables exist but aren't enabled for every OS.
    1972 Triumph Spitfire Ecotec Swap:
    Stage 1: MEFI-4B & L61 - deceased; ate it's own balance shafts - because I did a dumb.
    Stage 2: E37 & GenII L61 - Ran great, but too meh.
    Stage 3: An LSJ is a good time in a 2000# car.
    2005 GMC Canyon base work truck.
    LS Swap, AR5 Trans, BCM transplant, Sierra Dash, G80
    5BA8
    5,577
    Alvin would know. He has more TBSS experience than anyone active on the board.
    email=[email protected]
    North Carolina
    4,939
    Get rid of the VVT would be my recommendation.. No one trying to make serous power with a GEN 4 uses it.. It just adds complication. They rarely have good VVT control if the thing spins a decent amount of RPM. not worth it.
    Oct 2014
    Moscow, Russia
    330
    Discrete AC request can be enabled in any E67. I can do it.
    P.S. Can you post stock GMPP 6.0 calibration?
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
