Results 1 to 16 of 16
Thread: Base tune for a 2020 silverado 5.3 with truck norris cam
    Jul 2025
    10
    I recently performed a dod delete and cam upgrade to a BTR Truck Norris. I don't really think the tuner knew what he was doing with the gen 5 l84. Truck stalls when I stop at lights. Im looking for a base tune that I can build of of my self.
    Jun 2025
    7
    who tuned it? was it someone local?
    Jul 2025
    10
    Quote Originally Posted by SideSwipe View Post
    Yes it was the guy that did the install of the cam and dod delete. But I don't think he knows what he's doing on the gen 5 tune.
    Jul 2025
    10
    Here is the tune file they put in the truck. It stalls when coming to a stop.
    can you post the stock read file?
    Tuning Addict
    7,184
    A lot of us on here tune for a living. I'm actually doing one of these with a rear mounted turbo and long tubes for a guy in Hawaii right now. These require more knowledge than just gen V's in general. Torque models have to match one another and all of the NN has to be dialed in for the setup...
    ~Greg Huggins~
    Jul 2025
    10
    [QUOTE=RaceReadyTuning;840319]can you post the stock read file?[/QUOstock tune-MY TRUCK.hpt this is the stock read file
    These will need to have the idle fueling dialed in as well pretty close to perfect to idle right and especially when returning to idle.
    Couple of things i saw in the file that we usually change when doing a camshaft.
    You'll have to make sure the NN is dialed in properly as well.
    Try this and see if it still wants to die coming to a stop.
    GMPsilverado 2020 jhon btr cam 5.3 my update - RR1.hpt
    Jul 2025
    10
    Quote Originally Posted by RaceReadyTuning View Post
    That solved the stalling issue. If you happen to see anything else that doesn't look right ill take all the advice i can get. Thank you
    if you want to message me a log of the truck I can see if I see anything. Just looking at the file I don't see anything that stands out crazy to me, but we all tune differently. It's really just going to be dialing in everything.
    Again, if you want to shoot a log, I can see if anything in particular is sticking out that needs to be addressed.
    Jul 2025
    10
    Here is a log from your update
    You're missing a lot of channels to see main things when tuning these vehicles.
    From what I do see, a lot looks great. You have some KR kickin in sporatically so I'd be looking in those areas as well.
    I can't really see the airflow models without logging the VE and Dynamic.
    Also need to be logging your IPW
    here is a channel list to load into it and get another log.
    Race Ready Tuning GM Gen V.Channels.xml
    Jul 2025
    10
    It won't let me open it on my scanner. Let me try to figure it out and ill post a log ASAP.
    Jul 2025
    10
    I was able to get it to work. Ill take a log on my way to work tomorrow and post it in the morning.
    Jul 2025
    10
    rr1log2.hpl
    Here is a log with the parameters you gave me
    Quote Originally Posted by Jonga420 View Post
    rr1log2.hpl
    Looks really good.
    There are areas where your airflow models need work still and are pretty far off from one another. That and the idle needs to get the timing up a bit. But you're moving on the right track for sure.
    Build yourself some graphs to reference airflow error between the MAF Airflow vs Dynamic, as well as the VE Airflow vs Dynamic. Once the Airflow models are right, then start working the VTQ.
