Results 1 to 14 of 14
Thread: Bad tuner?!
    Jul 2025
    7
    Bad tuner?!
    Hi so I have a supercharged (2.9l whipple) cammed pontaic g8 gt,got it back today from the shop that installed the supercharger and they use their own tuner(first red flag was he couldn't get the car to idle after trying for a whole day) keep in mind I don't have a afr sensor(planning on getting one) and I logged a few cruising and light pulls on my way back,car would show misfiring sometimes straight into kr,keep in mind I'm running methanol injection and octane booster to boost my octane to 103 octane so fuel should be a issue,ait was around 30°c and coolant was at around 88°c so air should be a problem,I noticed that bank 1 and bank 2 for short term fuel trims were waayyyy of aswell as long term fuel trims,could anyone give me some advice cuz I'm very interested to know what could be causing this,also I think the tune is running way to mutch timing in lower rpm,but then again I really don't know mutch about tuning,any help would be appreciated,I basically want to know if I'm cooked or not and if I should get a new tune asap and if this tune will hurt my engine(hasn't hone wot yet for this reason) thx for listening,I would attach the vcm scanner logs but I don't see a option to do that,also his tune is locked so I can't "fine tune" or correct it25-07-27 16-04-13.hpl25-07-27 16-13-45.hpl
    Last edited by lunar; 1 Day Ago at 01:16 PM. Reason: adding vcm scanner logs,since tune is locked
    North Carolina
    4,927
    We can't tell anything by a description other than its obvious you have issues.. Log and tune will help.
    2,854
    without tune logs or at least screen shots of the problem area, it would only be a worthless wild guess
    Dec 2019
    MS
    1,315
    Take it back and let him fix the tune or unlock it so you can have it fixed.
    Majority of the time a locked tune is just hiding a hack job.
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,170
    Sounds like you need to fix the tune. That is where I would start.
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
    Advanced Tuner abc's Avatar
    Jan 2024
    967
    Yep, tell him to unlock it or you will have it unlocked. After it's unlocked, post it here and we can take a look.
    Dec 2019
    MS
    1,315
    Quote Originally Posted by abc View Post
    Who can unlock the E38? Ive never tried that.
    Aug 2021
    1,170
    Quote Originally Posted by RDF1 View Post
    I have never used his services, so this is not an endorsement, but this guy can:
    https://www.customecm.com/
    MAF Assistant
    EOIT Assistant
    North Carolina
    4,927
    We can unlock GEN 3 and 4 ECM's
    Jul 2025
    7
    Hi i manage to get some vcm scanner logs if youre willing to take a look
    Jul 2025
    7
    managed to get some vcm logs of the car if youre willing to take a look
    Jul 2025
    7
    here you go i managed to get some vcm scanner logs
    5BA8
    5,557
    22 degrees of timing at 155 Kpa and 4000 RPM. That's freakin scary. Must be really good fuel. On 93, even with spraying some meth, you're breaking pistons.
    email=[email protected]
    Jul 2025
    7
    im running 99% methanol injection and octane booster to boost my octane from 95 to 103 octane in the tank
