Thread: Configuration for an E85 setting
    Jan 2025
    12
    Would anyone care to look at my setup for an E85 tune for a 2018 Camaro 2.0 turbo and tell me what needs to be changed to make it cold start?
    24-07-2025.hpt
    Thanks in advance for your helpful advice.
    Jan 2025
    12
    I downloaded a baseline setup, whoever made it had a Camaro SS, is this setup valid for all engines?
    2016_ss_flex_fuel_baseline.hpt
    Mar 2024
    DMV
    29
    are you using the zzp e85 kit?
    Getting it started shouldn't be that difficult
    Cranking Fueling/airflow etc
    timing high octane
    idle tables
    and also adjust all the flex fuel stuff
    theres a couple more steps but it should be pretty simple for you to get it to just start up
    also no an ss file wont work with an ltg file different engines different ecu, there is very little you can copy from that for it to work.
    Jan 2025
    12
    Hello,
    Thank you for your reply!
    Quote Originally Posted by vthex View Post
    I'm using an E85 kit, but I didn't purchase it from ZZ Performance.
    According to the description, only the Flex Fuel-specific settings are modified; the basic settings are retained. The title reads: "6th Generation Camaro: How to Tune the Engine for E85," but it doesn't specify that this is only for the SS.
    The video clearly states that any modifications to certain tables are at your own risk.
    Here's the video: https://www.youtube.com/watch?v=7gaMNaFBVYQ
