Results 1 to 2 of 2
Thread: BA NA+T with Kelford 218B cams
    Apr 2022
    40
    Hi guys, have a BA Falcon here NA+T 3584, kelford 218b cams, 1000cc injectors auto built btr with 3500rpm stall.
    Having issues getting it to idle correctly so i can proceed with the tune.
    Is there anyone on here able to point me in the right direction, keen to learn.
    Stock File Attached for reference.
    Apr 2022
    4
    Hey there, very hard to find much advice here...
    theres quite a few things wrong with that file... Injectors need scaling ,turbo logic not active,map/boost fueling ,etc etc just to name a few.. question ..Has the map sensor and fuel reg been changed? fuel pump done? ill send you a file you could work with to help you out.. cheers Ray H from NZ
