I have L84/8l90 E90 setup that I have been troubleshooting for a month now. Regulated fuel system set at 72psi but only getting 150psi at fuel rails and sometimes less. Vats and starter diagnostics disabled. I have spark and motor will run on ether. No current DTC present. Scanner reads RPMS and cam counts. Not seeing injector pulse and desired fuel pressure is reading 0. I also noticed when the motor was running on ether it was still showing 0 oil pressure. I have included logs. Log shows it running on ether at 4600. Desperately searching for help. Thanks in advance.
log1.csv
