In the scanner, does the reported IPW number ignore:
- fuel injector characterization modifiers (vacuum, voltage, temp offset)
- fuel trims
My understanding is that the scanner IPW values reflect airflow into the engine, injector flow rate (at the current fuel pressure) and commanded AFR. So if you are running lean or rich at any given time IPW would not deviate.
Here is an example of what I am talking about: https://forum.hptuners.com/showthrea...l=1#post682824
Side note: what ever happened to HJTRBO?
