Results 1 to 10 of 10
Thread: Having odd TCC lockup issues all the sudden - trying to understand TCC lockup tables
    Jul 2021
    26
    Hi there - for the last month or so I've been experiencing some odd TCC lockup issues with my 7.4/4L80e setup. This all started to happen after changing out the trans fluid, and it seems the tune is directing the TCC to engage in 2nd gear and at light throttle.
    Am I reading this correctly?
    Philip
    Edit - also what determines the normal/economy/cruise modes in the apply/release dialog?
    Mar 2024
    45
    its not commanding to lock on 2nd until you go over 87% throttle position , on 3rd and 4th it is commanding to lock up at light throttle position
    Feb 2024
    396
    Is it in economy mode? Im not sure what controls this, if there is a button to toggle it on or off? This would explain the low speed, low throttle TCC lockup occurring. Look at the Lockup speeds/throttle position for 2nd gear. Need to post a log, TCC channels, speed, rpm, and throttle position at the minimum.
    Dec 2019
    MS
    1,325
    Do you have a datalog?
    IF trans hot has been triggered by a false input it could lock in 2nd at very light throttle.
    What codes are you seeing?
    Jul 2021
    26
    That?s what I thought too, and that?s how it?s behaved since I?ve owned the truck, but now it?s locking when hot, and I?m just noticing the different mode tables. I have no mode buttons in this truck.
    Jul 2021
    26
    Yeah this was confusing to me as well. It?s like it switch modes suddenly. Or maybe it?s in hot trans mode and my cooler is fully plugged with stuff?
    Jul 2021
    26
    I will make one - one thing that?s confusing to me is does an added log parameter automatically create a graph in the graph window? Does it matter?
    2,865
    A parameter will not create a graph by itself. And your graphs aren’t part of a log file. It is strictly the data that is included. It will load into any graphs that are in use by the scanner that is set up for the channel.
    Dec 2019
    MS
    1,325
    I dont remember if the old pcm will show you which mode its in. Its worth a shot to see.
    5BA8
    5,576
    Need to post a data log so ppl can see what it's doing.
    email=[email protected]
