Thread: BF NA +Turbo tune
    Nov 2022
    BF NA +Turbo tune
    Hi everyone, new here and wanting to compare my Base tune that I was given. Its currently running wastegate pressure (4psi of boost). Its been running like this for the past year and a half as a daily and I have no issues. I'd like to slowly start messing around with it.
    Has anyone got access to a tune file for a NA +T tune for around 7-9psi of boost?
    I have attached my tune file.
    May 2025
    AUSTRALIA
    8
    is this for The ZF6 ?
    Nov 2024
    4
    hi mate, looks like youve attached a scanner file instead of a hpt file, would you mind adding the tune file
    Apr 2022
    4
    Hi Mate -Have you got your tune file there rather than the log? But Looking at the log looks like afew things not looking right..Appears engine cooling is needed,also looks like your only around 2-3psi boost to name a few - if you send your tune file i can maybe help..Cheers Ray H
