Results 1 to 12 of 12
Thread: Supercharger wheel for 260
    Jul 2024
    11
    Hi I was wondering what?s the best wheel to get for supercharger for 260 hp seadoo and can I run it with just a rising rate fuel pressure regulator and pump or do I need bigger injectors thanks
    Jan 2006
    DFW
    262
    I am running a drop in wheel with no other fuel mods.
    2008 Denali XL AWD LSA Blower
    2010 CTS-V
    2005 LLY Duramax SAS
    2015 Denali
    Tuner in Training activejetsport's Avatar
    Sep 2023
    37
    Quote Originally Posted by Scooterman2025 View Post
    We have a wheel that does 16 psi at 8700 RPM. Yes, you should run larger injectors with a wheel making that much boost.
    Sea-Doo / Yamaha Performance Parts
    https://activejetsport.com/
    Jul 2024
    11
    Quote Originally Posted by activejetsport View Post
    What injectors should I run and do I need to run a rising rate fuel pressure regulator too or can I just run bigger injectors
    Sep 2023
    37
    You only need a fuel pressure regulator if your stock one is having issues. Rising rate is really only needed for high boost applications where the boost pressure is so high it pushes back on the injectors enough that it prevents proper fuel atomization. This is for high boost turbo setups.
    You would want the VT1100 injectors.
    Tuner in Training RUTHLESS RACING STORE's Avatar
    Sep 2022
    FLORIDA
    43
    The wheel won't get much gains, you'd be better off doing camshaft and titanium retainers
    IG @Ruthless_Rxpx
    Jul 2024
    11
    Quote Originally Posted by RUTHLESS RACING STORE View Post
    Does the stock pump change pressure or does it stay at a constant pressure
    Sep 2023
    37
    Pre-325 models use static fuel pressure of 58 psi. It will drop slightly at high RPM but that is normal and you account for that during tuning.
    A wheel will give you a significant gain over stock. The normal upgrade process is a wheel and then, if you want more, a cam.
    Sep 2022
    FLORIDA
    43
    You're referring to your 260 fuel pump, which is operating at 56 psi of pressure. I recommend changing it to AEM 340, which is like $98, and a relay from https://brtparts.store/collections/f...55-230-260-300
    IG @Ruthless_Rxpx
    Jul 2024
    11
    On hp tuners for my 2012 tune it won’t let me adjust injector voltage offset above 1.6 that’s the max
    Sep 2022
    FLORIDA
    43
    Quote Originally Posted by scooterman2025 View Post
    on hp tuners for my 2012 tune it won’t let me adjust injector voltage offset above 1.6 that’s the max
    contact us with the injector purchased order number and we'll get them dialed in for you *1800-307-9635
    IG @Ruthless_Rxpx
    Jul 2024
    11
    Okay will do thanks
