Thread: Very lean on E85
    Jan 2022
    26
    Very lean on E85
    I've been battling my 2012 C6 over the last couple of days. Car was MAF only and had drivability issues. It was also running E so I know the car should run on it again. I went to a 2bar OS and was finally able to get my VE table pretty well dialed in. I still have a slight buck at low RPM (thanks to those who helped with that) but I think its about as good as its going to get. I still have 55 gallons of E85 left over from a car I no longer have so I figured it may be a good time to tune this car for E85 since it already has the fuel system for it. I'm running Fore triples and ID1300 injectors. I thought I had everything enabled that needed to be. During the first startup the STFT are 25%'ish lean. The log shows the E content is about 50% but the car is acting like its not recognizing the E content. I upped the PE EQ alcohol ratio by 20% just to see if I got a response and I did not. Do you guys have any idea what may be the issue?
    E85 startup.hpl C6 Tune 57 Custom OS E85.hpt
    Senior Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    1,029
    Why is Stoich 28.
    Australia
    2,065
    yea the flex sensor can only adjust when the stoich is correct, just go back to stock values and double them if ur doing the double stoich half IFR deal
    Jan 2022
    26
    Got it. Thanks guys. I really appreciate your help.
