I would like to figure out how to properly tune/train my ram.
I am willing to pay for assistance in learning and/or for the training.
Would appreciate someone pointing me where to go for proper assistance in correctly tuning my truck.
I seem to be finding various ways that are claiming to be the correct way. I suspect this is due to the different models and what not.
I would like to learn how to do this so i can continue to tune it as i mod it over the coming months and years.
Any assistance would be appreciated whether its on a personal level or general training. HP Tuners did not have any training options on their calendar so looking elsewhere.
Currently it will start and idle for 1-2 minutes before it slowly idles down and dies. I understand the basics and why its happening, this was part of the plan, to learn as i go. :-)
Vehicle and mods: 2015 Ram 1500 sport, upgraded cam w/phase limiter (specs in link below), ported heads (intake and exhaust side), port matched and cleaned up intake manifold, shorty headers (linked below), stock cats and exhaust other than headers. 8 speed auto, 3.92 final drive.
Oh, also cold air intake.
Stock injectors also, if those should be upgraded or any other fuel upgrades should be considered with these mods, info is always appreciated.
Exhaust upgrades will likely come later in the form of muffler/resonator changes, but will be sticking with shorty header's though as i dont want to deal with removing the cats.
Cam: Brian Tooley Racing - Truck Norris
Cam card: https://imgur.com/a/ASraPaI
Headers: BBK Shorty headers
I have attached a mostly stock tune file. I understand Neural training uses different files but im not 100% sure how to get there yet.
This file is stock other than:
Disabled MDS per HP Tuners video
Adjusted Fan temps as removed the clutch fan and installed a V6 fan/shroud.
Set Idle speed to 752
Other than that, this is a stock read. If you want the 100% stock without the items above done, i have that also.
Happy to provide scanner files after it gets running enough to move around. Or if you want me to get what i can around the block or so, let me know if it needs warmed up first or can be cold, or just run it around cold for a moment.
Thanks in advance for any help.
Side note, it sounds so good when it runs, very excited to have this running at its potential!
