Results 1 to 2 of 2
Thread: running lean and chops without a cam
    Apr 2025
    14
    I have a 2006 silverado 1500HD that had a 6.0 with a 4l80e. the 6.0 took a dump and all i had at the time was a 4.8 out of a 05 silverado. i swapped the 6.0 for the 4.8 and used the factory harness along with all the same sensors. once i finished the swap and started it the idle was extremely high so i replaced the throttle body with the one from the 05 silverado that helped it however it was still sounding like it was cammed so after some research i found that the maf sensor could be the culprit due to it having the parameters of the 6.0. so i went to the tune repository and found a "stock tune" from a 2004 chevy express with the 4.8/ 4l80e combo and segment swapped it. that still didnt fix the issue so i bought a new maf and that didnt fix it either however i found that when i run the truck without the maf sensor it idles fine and i have less issues. it still runs lean but not as bad. Here are the specs of what is in the truck along with data log and tune file.
    Tune AND data log
    Engine: 4.8
    Axle gear ratio: 4.10
    Tire size: 35x12.50R22
    Computer: P59
    Operating system: 12592618
    Heads: 706
    Transmission: 4L80E
    Torque convertor stall: Stock
    intake manifold: Stock intake from 6.0
    Intake tube: Stock box
    Air filter: Fram
    MAP part number: 213-4434
    MAF part number: AF10043
    Injector part number: 17113698
    cam used: Stock 4.8 cam
    exhaust type: Long tube 1-7/8 headers no cats
    pistons: Stock 4.8
    compression: Unsure
    throttle body type: Stock DBW
    Fuel pressure at idle: 58PSI
    25-07-31 18-40-37.hpl4.8 copy cat from 04 4.8 as found with 4l80e segment swap attempt to fix battery light.hpt
    405
    3,254
    First you cant mix 06-07 classic ETC hardware/calibrations with 03-05 ETC hardware/calibrations.
