Results 1 to 3 of 3
Thread: Multiple PCM failures
    Jul 2022
    Roxana, IL
    134
    I LS swapped a 2000 S10 to a LM4 from a Trailblazer/SSR. At first I had a battery light that stayed on. A different PCM with an OS that was more compatible with an S10 fixed it.
    Since then, I have had 3 PCM's fail. It's always the same scenario. I'm backing out of a parking spot, stop and put it into the D quadrant and it dies. Cranks but won't start. The first time I checked it has no fuel/no spark. They seem to last 6-8 months at a time. I can put the original PCM I bought from CPW back in and it starts and runs fine. I just have the battery light back.
    1 PCM was a Flash Masters unit, the other 2 where from used vehicles that I had GM program a specific vehicle to and then I would use HPTuners to swap my tune file over.
    Tonight, when I got home. I used a bench harness to read the tune file. I got an error message of "Detect Controller and Get Basic Info Failed" with HPTuners.
    My questions for you are:
    Has anyone ran into this before?
    Where should I start to diagnose this type of failure?
    Building Automatic Transmissions since 1978
    "Most people do not listen with the intent to understand; they listen with the intent to reply."--Ernest Hemingway.
    Black 2000 S10 Base 2.2L Flex Current LS10 swap project
    Red 2000 Blazer LT 4x4 3.73 SOLD
    Red 1998 S10 SS 4.3L Deceased 10/31/2014
    Oct 2014
    Moscow, Russia
    330
    Check for loose powertrain ground on the rear end of the left cylinder head.
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
    Jul 2022
    Roxana, IL
    134
    Thank you for your reply.
    That was the first thing that I did was to check all the grounds.
    Now this morning I backed it out again and it died. I have to assume that the PCM is now bad or bricked.
    Do you know anybody that can look at a bad PCM and analyze it?
