Results 1 to 8 of 8
Thread: e78 sierra 2500 2012 set fan electric
    May 2023
    hi all
    my car is sierra 2500 2012
    "I have installed electric fans for a 2013 GMC, and I have connected all the wiring correctly. When I tested the low and high speeds using the VCM Scanner, they are working. However, I want to adjust their programming, but I cannot find any option for that. Can you help me?"
    Dec 2019
    MS
    1,327
    Ive often seen where this can be a big issue with the E78 in the 2500 Trucks. Fans work with scanner but the ECM wont control them by ETC/AC pressure.
    North Carolina
    4,937
    TO my knowledge it's not possible to get a E78 to run efans. I could be wrong. would love it if someone proved me wrong.
    E38 trucks only.
    Dec 2019
    MS
    1,327
    E38 trucks only.
    Thats what ive found out. Ive tried a few E78s in 2500 trucks with no luck.
    Jul 2025
    3
    Did you find a solution for that?
    Aug 2020
    4
    for the past 3 years i've been studying this issue regarding the 2011+ e78 ECM's and now i successfully achieved my goal.
    so for starters my car is a 2015 GMC SIERRA 2500HD 6.0 L96 engine so i made them run while outputting a PWM signal from (X1 pin 41) and it works flawlessly no issues whatsoever but haven't tried the two speed function but i assume it will work also.
    you need an costume calibration file which i have to install on your specific ECM + 1 pin change on your X2 connector and you should be good to go.
    this calibration file can only be installed when you ship your ECM to me its a very dangerous file that could end up killing your ecm if 1 miss step happens.
    E78 ecm drama is now finaly gone
    Aug 2020
    4
    Quote Originally Posted by Ammar LS View Post
    ship your ecm to me in kuwait
    Jul 2025
    3
    Im from saudi arabia but Do you know someone who is good at programming?
