Results 1 to 10 of 10
Thread: 6r140 4x4 low range
    Jul 2025
    pa
    5
    6r140 4x4 low range
    When in 4low on every 6r140 in a 6.7 that I have seen they start in 2nd gear, what is changed to make it do this ? I cant seem to find how its done as I want to make it start in 3rd gear in 4 low so I can put the truck in drive while starting in 3rd gear for sled pulling and alow it to shift up on its own.
    Sep 2021
    45
    I just looked at my stock trans file and the 4x4L shift table has 1-2 shift set as -5 down the whole table. Maybe do the same for the 2-3 shift table (set to all -5) and try it out.
    Jul 2025
    pa
    5
    What year is your truck ? This looks different then my file
    Sep 2021
    45
    Quote Originally Posted by Jwperformance View Post
    2013
    Sep 2021
    45
    It's probably the same if your table looks like this...change the 2-3 to 300.
    Jul 2025
    pa
    5
    Yep that?s what mine looks like, but my 1->2 isn?t 300 like yours, it starts at 340 and goes to 1000, but I think your onto it, I will set both 1->2 and 2->3 to 300 and see what it does.Screenshot 2025-07-31 211546.png
    Sep 2021
    45
    I don't think your 4X4L table is stock. I looked at 2017, 2018 and 2019 stock files and they all look like this. 6th gear is locked out of 4-low.
    Jul 2025
    pa
    5
    The truck is tuned so they must have changed it but what I didn?t get was why it still was starting in 2nd with the table looking just like the normal table.
    Jul 2025
    pa
    5
    Update, tried 250 in the first two rows and still starts in 2nd gear, Mabye they need to be negative so it thinks it cannot use those gears.
    Sep 2021
    45
    I bet it's coded and only accessible with user defined parameters in the binaries. That's above my skill level. You may have to set the downshift tables lower as well. ChatGPT says set the 1-2, 2-3 and 3-2, 2-1 to zero or "unattainably low numbers"
    You could also submit a ticket and see if the HPT engineers know of a table for each drive mode vs starting gear.
