Thread: Dumb Fans Question...
    Hi,
    If you read my other post you can see I am new at the LS2 tunning. I am used to seeing the following when changing the LS1 fan settings and am now seeing the paramenters for the LS2 but am confused.
    I want to change the fans as follows:
    Fan 1 set the On at 205 and the Off at 198
    Fan 2 set the On at 212 and the Off at 205
    But am concerned that I am changing the wrong paramenters based on the words that appear now.
    Would the following achieve what I want:
    Enable ECT A: 205
    Disable ECT: 198
    Enable Hi ECT: 212
    Disable Hi ECT: 205
    I have not loaded the tunning into the car yet, waiting for someone to answer first.
    Thanks in advance.
    Luis
    BTW Stock settings on my 2007 Corvette are:
    235
    235
    266
    262
    2007 Blk/Titanium-two-tone Coupe, A6, F55, 3LT, NAV- Built 12/13/06. Delivered 1/12/2007!!
    SOLD - 98 Black A4 Vert - Mods: Blackwing, LS6 Intake, 160T-Stat, TiExhaust, Z06 Swaybars, Baer Rotors, Y2K Polished wheels, & Vortech V2SQ 465rwhp/427rtrq
    Tuner Street Legal's Avatar
    Mar 2007
    Houston, TX
    162
    the LS2 FAN is PWM you can change the % OF the on time just go under FAN DESIRED VS ECT and change the % of the ON TIME like 75% 80% 90 %...100% is the MAX FAN SPEED
    Quote Originally Posted by 98VertPDX
    Hi,
    Enable ECT A: 205
    Disable ECT: 198
    Enable Hi ECT: 212
    Disable Hi ECT: 205
    Thanks in advance.
    Luis
    235
    235
    266
    262
    those for turning the FAN on after shutting the engine OFF
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,256
    Try these settings for a stock thermostat. I would install a 160* stat & shift the table one cell to the left.
    You have to leave the 192 cell at 0 for the fan to turn off.
    Russ Kemp
    Quote Originally Posted by Russ K
    Russ Kemp
    Thanks! This is exactly what I was looking for...
