Thread: Hey Bill (foff) or any diesel pros
    Tuner 2000C-5's Avatar
    Oct 2006
    Powell, TN
    186
    Now that I have your attention.
    I have a buddy at work that is wanting me to tune his Duramax. The problem is, his is one of the funky 2006 LLYs. From what I understand, this is a sort of a LLY with LBZ electronics. I tried to just connect the scanner and it told me that there was "no power from the vehicle, make sure key is on and in the run position". I don't know if this has anything to do with it, but while I was trying to connect, my firmware updated from 106 to 110 (I believe that is right).
    So, since this is sort of a hybrid LLY , does that mean it isn't tunable yet?
    28,771
    support would probably be the contact place that would serve you best...we currently only support up to 05 so im not sure when the 06 LLY's will be supported.
    Oct 2006
    Powell, TN
    186
    Quote Originally Posted by foff667
    Support? This is under "contact" on the main page? Thanks.
    Yup, Chris mentioned they are aiming for a March release at this point for LBZ as long as everything goes smoothly.
    Everything going smoothly?
    Advanced Tuner CRASHNBURN's Avatar
    Jun 2007
    Mn
    240
    It is better for all of us that they take their time now. Let the beta people find all the bugs now, rather then later. The LBZ & the "2006" LLY are the same motor. The 2006 LLY is just a detuned LBZ. I would bet that once the LBZ software is out so will the 2006 LLY software. Gm totatly changed there software. It does take time to learn it.
    2006 LBZ Duramax 4x4 CC SB 2500HD SRW 4x4 LT1 (with extras), Blocked & Fingered, Fumoto drain valve, Keystone Ram Air Good Hood, Banks Ram Air, Access cover & Rhino over the rails, Victory Red.
    33'-0" Dutchman fifthwheel,Tekonsha Voyager Brake Controller
    Banks Sixgun with HPTUNERS.
