Results 1 to 6 of 6
Thread: Is there a parameter for A/F ratio when the throttle is cracked from a dead stop?
    Tuner Mike04's Avatar
    Feb 2007
    Orange Park Fl
    104
    Is there a parameter that controls the addition of fuel when the throttle is cracked from a dead stop?
    When I give my car a normal acceleration after setting at a dead stop for 30 seconds or so, my A/f dips very rich and I can feel the car hesitate for 1/2 a second. It doesn't do this every time. I can't see where IAT has an affect. Could this be a heat soak issue?
    RHS Block 427, Mast/ PI 275 Heads, A&A YSi SC, 3.125Pulley, 238/254 LSA116+5, Flip Drive, AR 1 7/8 Headers, Corsa Touring Cat Back, RPM Level VII Tranny/ Flexplate/ Drive Plate, PFADT Carbon Fiber Drive Shaft, RPM rebuilt DTE Stage 4 3.42s, Vigilante 3 Disk 2600 converter, Custom Fuel System with Dual A1000 Pumps, ID 1000 injectors, Triple Nozzle Alky Control, 3 Bar SD Tune using 2.5 MAP. 935rwhp 800rwt
    Banned vette_doc's Avatar
    Dec 2006
    192
    post your scan and tune file
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    VE table too rich? MAF table too rich?
    Are you running 2 bar yet? You should be with your boost level.
    Always Support Our Troops!
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Quote Originally Posted by EC_Tune
    Exactly, if your car is doing that, it sounds like you need to revisit VE/MAF (if you have it) tuning.
    Sulski Performance Tuning
    Feb 2007
    Orange Park Fl
    104
    I'm hesitant to go with the 2 Bar. I'm not confident enough in my abilities to do it right yet. I am getting really getting tired of chasing my start up issues (car tends to hange at about 400 rpm ever now and then for a second or two) and the above posted issue.
    I'm just about to the point of giving up and trying the 2 Bar, what do I have to loose....
    I wonder how many hour I have into this tune
    Apr 2003
    Almost 2000 feet.
    7,876
    You may find that tuning *just* the VE table will be easier than you think.
    Here's how I set up 2 bar VE tables.
    Copy your old VE table up to 105 Kpa to the new VE table (2 instances of the editor are required, old tune & new 2 bar tune).
    Then go to the 210 Kpa line and from 0 to 1600 RPM put 120 in the table, from 2000-3200 put 130, 3600 to 5200 put in 160 and 5600 up put 130 in the table. These values will probably be high but it's a good start.
    Now use the Interpolate between Vertical Bounds Attachment 6717from 210 Kpa to 105 Kpa and you have a startup VE table.
    Use your AFR error % to adjust it. Once you have it ~-1% you're good to go.
