Page 3 of 3 FirstFirst 123
Results 41 to 49 of 49
Thread: Real Time Tuning
  1. #41
    Feb 2006
    WPB, FL
    372
    Any way to solder on some more ram? Maybe hack up a 99+ PCM, steal the ram and solder it on? I know, I know that I could just switch to a newer PCM, harness and cluster...............man, it makes my knuckles bleed just thinking about this.
    98 Z28 370 LQ9 w/ TH350, FTI 4800 Stall, OLSD, NW90 TB, 80# Motron Inj, AFR 225's, 231/231 .624/.624 114, Mamofied FAST 90 Intake, PT88 Front Mount w/ 4" DP dumped before the Strange S60 w/ a 3.73 gear
  2. #42
    28,320
    probably...but thats alot of work for 1 year pcm...thats why moates didnt even do it.
  3. #43
    Sep 2002
    Chicago, IL
    6,397
    You could upgrade to a 99 pcm and buy the 98 to 99 adapter harness from Speed INC?
    I'm pretty sure they have some harnesses.
    We got this guy Not Sure, ...
  4. #44
    Aug 2004
    UCSB-Chemical Engineering
    171
    no. they dont have them anymore. they had problems.
    98 Camaro, M6, HPTuners, heads and cam
  5. #45
    Sep 2002
    Chicago, IL
    6,397
    Interesting, I wonder what the problems were.
    Fuel level gauge wouldn't work.. I think the EVAP system may have a couple of differences as well..
    I run a 02 engine harness and PCM in my 97 wired race car chassis (almost identical to 98)..
  6. #46
    Aug 2004
    171
    i dont know. i read some threads on tech about people calling up speed and they said they dont sale them anymore.
    poor 98's why are we cursed with the special pcm.
  7. #47
    Sep 2002
    Chicago, IL
    6,397
    Well you could try speartech and see if they make some.
  8. #48
    Apr 2007
    Los Lunas, Avondale
    79
    can the 1 Bar Maf enhanced work for Turbo applications with a blow through maf setup with less then 14.7 PSI? Or will I need to get the 1 Bar SD and just use the MAF anyway?
    2002 NBM WS6
    APS F-BODY TWIN TURBO KIT
    317 Heads
    60# Mototron Injectors
    HPTuners tuned by Sean@Solid-Technology, Abq NM
    610 RWHP DYNOJET on 7.9PSI
  9. #49
    Apr 2007
    Los Lunas, Avondale
    79
    Also I was making changes in the VE table and the AFR keeps going up or down accordingly and then goes right back where it was before I made the change. What do I need to do to combat this so that I can find the best values in the cells for the AFR I am striving to achieve?
    Thanks in advance,
    Fil131
    2002 NBM WS6
    317 Heads
