I am getting a tune ready for 60lbs injectors. to start I want to change the injector flow rate table. easy enough I thought. just put in the values once calculated.
as I enter the values I was surprised to find the following. I cant enter a value greater than 8.000 Grams/sec or 63.493 lbs/hr.
Why is this happening. I tried to look around the editor to allow larger values. I also search the forum for the same problem.
if it matters I have the following.
LSJ 2.0L stock injectors 32lbs, currently with GMS2 45lbs injectors, now putting in 60lbs/hr @ 43.5 lbs fuel pressure.
the LSJ fuel rail is 58psi so the flow rate is greater than 60lbs/hr.
thanks for your help in advance!
