I am helping a friend (who is helping me with some fabrication chores on my BMW M3 402 LS2 swap) with his truck.
2003 Hummer H2, 408 iron block with a Magnuson blower. Figure around 700 hp, give or take. Stock 4l65-E's seem to last for several months then the output shafts snap. He wants to convert the truck to a manual transmission.
I think I have the research done to be able to do the physical installation to get the NV4500 and transfer case (either whatever is native behind a NV4500, the electronic version of the same or an Atlas Case) installed in the truck.
I have some questions about the electronics.
I apologize if these questions are basic, but I want to make sure that I know what needs to be done.
The plan will be to use HP Tuners (which I should have by that time). I have done tuning using other programs on non-GM applications, so I am familiar with it, but have never done anything like this.
1. Does HP Tuners have the capability to change everything necessary to have the truck run with a manual (assume that stuff like the clutch interlock is taken care of and that the base tune is not going to be altered)?
2. What, if anything, needs to be done to the traction control system and can HP tuners do it?
Thanks in advance for any advice or a point in the right direction.
