If you put "0" for target RPM in the tables, does that
work like other things as an "ignore" and then maybe
just run off airflow targets alone? Or is this a recipe
for crank-n-die?
for crank-n-die?
Never tried it, but sounds like a "crank-n-die" since the correction tables will try to keep it at that RPM. Any reason why you are trying to defeat Idle RPM Control?![]()
It will still run if you command it in RTT, as far as cranking, I am not too sure.
Sulski Performance Tuning
