I am very new to tuning my car. I got HP Tuners in the mail today. I drive a 2000 Camaro SS with an LS1, all info is in the sig. Currently my ac-on idle is fine, but when the ac is off the idle isn't very good. It will bounce from 450 to 600 and not sit there. It does it a lot more when the car is in gear than when it is in neutral or park. I looked into what I think was the IAC and it was set to as low as 500(rpm) if the temp was hot. Is this correct? Also, when I get on it, I hit about 6200rpm when I should only be getting to 6000 or less. I found where there is a fuel cutoff in neutral and park at certain rpm's but couldn't find for when i am driving. Also I know I need to change my shift points but havn't had the time to do that and run the car to see how that controls the shifts. Thanks!
