Results 1 to 20 of 23
Thread: Help clearing secondary O2 sensors
    Aug 2020
    El Dorado Hills, CA
    Cool Help clearing secondary O2 sensors
    Hello HP Fam!
    I own HellKitten: 2018 Chrysler 300 (392 Stroker, 2.9L Stage 3 Whipple)
    I have been working with a reputable tuner, and upon finishing up the touches, am trying to clear my check engine light, but it keeps throwing codes and coming back on. My tuner has suggested that I come here and ask how to clear secondary O2 sensors. They are unable to do this for me as something about emmissions rules etc etc.
    I am getting the following:
    P0038 - HO2S Heater Control Circuit High (Bank 1, Sensor 2)(Pending, Current, Permanent)
    P0058 - HO2S Heater Control Circuit High (Bank 2, Sensor 2)(Pending, Current, Permanent)
    P0138 - O2 Circuit High Voltage (Bank 1, Sensor 2)(Pending)
    P0158 - O2 Circuit High Voltage (Bank 2, Sensor 2)(Pending)
    P219B - (Permanent)
    Looking for assistance. Fairly new to HP Tuners software, but am a computer guy.
    Thanks in advance for everyone's help!!
    Mar 2018
    Illinois
    873
    Don't think permanent codes can be cleared by any off the shelf scan tool or HP tuners. Such codes are cleared by the PCM once it sees the correct values. But if you remove O2 sensors then it will never clear but you can disable SES so you no longer see the light on the dash.
    https://forum.hptuners.com/showthrea...l=1#post592587
    Do you have a copy of the current tune you can post?
    Waldorf MD
    774
    The only other way to clear permanent codes besides fixing the actual problem is to flash the ECM using a dealer tool. I've done this with GM. Not sure about the Mopars tho...
    Daily Driver= 2003 BMW 330xi
    Quote Originally Posted by HellKitten View Post
    Hello HP Fam!
    P219B - (Permanent)
    well , if you have the hptuners mpvi just to go to the Engine Diag tab in the editor and search for the fault code and remove the check box that says MIL . i assume your tuner disabled COT and readiness in the ect rear sensor
    Waldorf MD
    774
    Quote Originally Posted by malikib View Post
    I tried this on several cars and the check engine light still appeared. The only way I was able to clear it was to flash the entire engine OS via TECH 2 (GM).
    Aug 2020
    El Dorado Hills, CA
    Thank you everyone for your input. I will parse this data and see what I can accomplish! <3
    Quote Originally Posted by jaydubb71 View Post
    Well you could write the entire os using mpvi2
    Waldorf MD
    774
    That wont work, unfortunately. Tried it...
    Did you disable the readiness in the oxygen sensors ? Also disable downstream sensors THen disable the codes by unchecking mil then write entire theN Clear the dtc that should get rid of it
    Waldorf MD
    774
    Yep. The problem is, the codes need to be disabled before the owner drives for any amount of time. Seen plenty of folks get headers and stuff installed on these newer vehicles and then drive them until they can get them tuned. The permanent codes get set and cannot be cleared. Even after disabling the DTCs. I tell folks to AT LEAST have the codes disabled before they get the work done. Then they will never ever have to worry about the codes again. Been there, done that. More than a few times. Too many to count.
    Aug 2019
    41
    Thank you for this insight, I thought this might be the case but have not tested it yet.
    Waldorf MD
    774
    Quote Originally Posted by joeapple View Post
    I have. And it works.
    818
    Is there a list of what to disable? I'm about to go down this road and already working on a file with everything turned off related to #2 o2 sensors and Cat efficiency or temp.
    Also, should anything be done in the actual tune as far as temps, etc?
    I have some pretty good ideas, just looking for confirmation.
    Waldorf MD
    774
    Anything secondary O2 sensor related. Including cat codes.
    Mar 2018
    Illinois
    873
    Ran across this recall where apparently permanent codes would not clear from the PCM and the solution is a reflash of the PCM. So I guess dealerships can clear codes but as jaydubb71 eluded to, it requires a complete reflash of the PCM.
    https://static.nhtsa.gov/odi/tsbs/20...70368-9999.pdf
    Waldorf MD
    774
    For the "tuner" I would contact oemtools.com. Im not sure of the prices though...
    Aug 2019
    41
    Spoolboy I can confirm what was said above is true, I have gone through all driving conditions 2 tanks of gas and no codes or rediness issues, when you get to that point I can post what I did, and there were no codes to start with it was in "street trim", some changes may be necessary some may not be but it worked great so far. here is last log file of light throttle drive home, 19 red eye ,1200cc fic inj and 3.17 hellraiser, midpipes stock other than that
    vcm scanner log
    Serial: T00EP0049GRBWT
    OS: 05035603AE
    Calibration IDs: 05035603AE
    Calibration VNs: B7BA7420
    Basic PIDs: 47
    Trouble Codes:
    Controller Type ID By OS: 0
    Diagnostic Requirements: None
    Scanning Methods:
    TCM: 7E9, CAN, TCM -TransmisCtrl
    Serial: T00UM318867800
    OS: 05035625AC
    Calibration IDs: 05035625AC
    Calibration VNs: 3583C3AD
    Basic PIDs: 12
    Trouble Codes:
    Scanning Methods:
    I may be wrong but it appears to me that i will not have any issues with this, at another time not so late, I can post my tune file for you or send it to you
    818
    If you're willing to share your tune publicly, go ahead and post it. If not, let me know and I will PM my email address
    I had an issue throwing a P113D code (o2 sensor High frequency slow to respond) or something similar. I disabled the light and stopped it from checking for this code as described above. I am very new to Tuning but with the advice of my Tuner it was easily accomplished. I know I have the Permanent Code until I can figure out how to add more response time for the code to clear (I had Long Tube Headers and high flow Cats added by a Reputable performance shop).
    Aug 2019
    41
    Hope this helps, remember i had no codes or cel before i put mids on and tune in! This is not a worked out tune but a work in progress! And possibly more needs to be done or less I imagine but it works for this purpose, race day soon so I need to get to work on the tune, so much to learn lol
    Did that help at @spoolboy
