In the bottom it says may causes issues with high rpm operation???
9.0s in '09 @ 153 MPH
Turbo 5.3 Volvo 740 Wagon
i have adjusted my injector gain and it was fine with light driving then with a throttle stomp it just lost all power for a sec then regained so i change it back to stock and problem gone, i may try it again and sneak it in with small steps and see how it goes encase it was too much at one time
I use it all the time on large boosted Eaton based superchargers. Haven't had any problems as long as you don't modify the driver demand tables. The ecm can't handle both modifications at the same time.
~Greg Huggins~
Does this function provide the ability to modify the fueling on individual injectors ?
Yes, just go with small adjustments at a time while reading the plugs. If you have any leaner cylinders you might be surprised by what you can gain doing this.
~Greg Huggins~
Good advice, this will help with the rear cylinders on LSA'sYes, just go with small adjustments at a time while reading the plugs. If you have any leaner cylinders you might be surprised by what you can gain doing this.
Is there a reference or picture for which injectors is which with the labelling ??
Forgot the table name, but look up at the top of the page. Should help you out there. I can post cylinders later if need be.
~Greg Huggins~
Yeah that's what I meant Cylinder A = 1 etc??
A1, B8, C7, D2, E6, F5, G4, H3
This Might help or at least get somewhat close on a Eaton
Cyl #A 1.01
Cyl #B 1.095
Cyl #C 1.055
Cyl #D 1.04
Cyl #E 1.095
Cyl #F 1.045
Cyl #G 1.06
Cyl #H 1
~Greg Huggins~
Sorry - gen 4 - desired throttle area tables - don't modify those and this both - will always put into REP and set ECM memory and logic faults...
~Greg Huggins~
i was using this just to help simplify which cylinder is what
2300+ 1900's with 15+psi, but won't need that radical of adjustments / The above tables are from a 2300 heartbeat running 18psi
~Greg Huggins~
Yes - big pain - I like to do 3 or 4 wot dyno pulls before even bothering to pull the plugs too - makes it easier to read them or instantly see fueling adjustments... Then maybe not tighten so tight until ready to call it good
~Greg Huggins~
I played with this table a couple years ago, trying to balance out a bank to bank imbalance I see at lower rpm. It seemed to help under 2000 rpm, but holy crap......WOT and fueling went bonkers. AFR was all over the place. I got skeered and put the table back to stock values, never messed with it again. This was an N/A application, so maybe it works better for boost?? Either that or I did something stupid and did not realize it at the time. Regardless, I would not mess with injector gain unless you have the WB installed and can verify WOT AFR.
When arguing with an idiot, make sure he isn't doing the same thing....
Tq Model is another set of tables that won't play well with this - Do not modify individual tables in the tq model and this table - have seen it lean out bank 2 if just modifying the airmass tables / BUT if you modify the tq model via tq editor - all seems to work good... That part applies to more tables then just this one though...
Also don't recommend adjusting this for bank to bank fueling - only adjust for wot cylinder to cylinder lean issues... Might be why wot fueling went screwy for you Michael?
~Greg Huggins~
I dunno....
Never thought to use it for WOT tuning of individual cylinders. How would you know which one is lean without an O2 sensor or EGT probe on every primary tube?
