Results 1 to 20 of 24
Thread: 08 HEMI 5.7 TURBO tuning issue. no power at WOT fine at part throttle AF good
    Feb 2024
    17
    0280298598 injectors. It seems that as soon as it gets into WOT there is no power, it slowly continues to climb in rpm but something is limiting it.
    if i drive it in part throttle conditions it drives good but as soon as WOT hits it falls on its face. what could it be?
    i included the current tune file if anyone knows a thing or two about hemis. thanks for your help!
    heres a vid : https://youtu.be/9rEmY4WreYw
    Aug 2020
    31
    post a log
    2010 Challenger R/T - 6.1 crank, Manley H-beams, MMX drop ins, Magnuson 2300, Snow meth stage 1, TSP Stg3 Boost Cam, Stainless Power Long tubes, Fore L2 return dual 450s, Hellcat TB, snout port matched to 90mm adapter, ATI 17% OD Lower 2.8 Upper, 14psi
    Tuner in Training jefo's Avatar
    Jul 2022
    36
    A couple of things:
    -Engine rev limiter should be at least 200rpm above the TCM RPM Limit. Your Engine rev limiter is at 5800rpm, and TCM RPM limit is 6000rpm.
    -Raise Torque limits under Trans Torque Management - Your engine limit is the stock 443lb-ft.
    2006 AWD 300C Turbo - stock 5.7, stock NAG1
    10.8@126mph on 12psi - WatTuned
    May 2018
    Germany
    590
    Thing I would change :
    sensed map - off
    ramp rate - not max out
    Driver Demand - set wot pedal the same as Pedal wot pedal tresh
    Engine Diag
    Raise Torque Correlation Data
    Just dont know max map for the 2 Bar sensor, but wont get over 200kpa.
    Good Luck
    Feb 2024
    17
    Thanks for your help guys i appreciate it. I've made some changes to the tune, but unfortunately cant go for a test drive until tomorrow. Tomorrow I'll see what happens and run a log. thanks!
    Jul 2022
    36
    I put together a modified version of your engine/trans CAL that should make it a bit better. Review the changes before running of course, and make sure AFR's are still good at WOT (Since sensed MAP is now disabled).
    -Engine fuel/timing mapped to 200kpa instead of just 180kpa; No change to WOT timing or fueling - except at 6krpm; part throttle timing at 105kpa lowered by 10 deg - boost at stoich part throttle and lots of timing is no bueno
    -Trans cal fully reworked - should shift quick and at ~5800rpm
    -A bunch or other little changes
    Was this a remote tune I'm guessing?
    Oct 2016
    Poland
    1,761
    Quote Originally Posted by jefo View Post
    A couple of things:
    Not really, exactly the other way around
    Feb 2024
    17
    08 Charger 5.7 Turbo newest file.hptmost recent 5.7 turbo.hplrt turbo wot issue.hpl
    all right! i was able to go for a test drive, it still has no power when going WOT. I've attached the current tune and also two logs. I appreciate your time. Thanks to those of you who have had some suggestions, i have changed some settings around and i still have the same issue.
    Feb 2024
    17
    @jefo I tried and its still doing the same thing, as soon as I go WOT it feels like the engine is cutting power and the turbo wont spool, if i go slowly into it as rpm goes up, the turbo spools up until i give it more gas then it cuts power again. Have you ever had a similar issue?
    Feb 2024
    17
    I've also posted a video to show what's happening, note: at the beginning after turning, i apply WOT and it does that. Thanks for your help!
    5BA8
    3,445
    It's not making any boost. Never goes over about 100 Kpa. Actually drops off as you keep the throttle wide open.
    I had a twin turbo Camaro come in years ago same problem. Turned out the turbos were seized up. Might want to verify that, and then check for boost leaks.
    email=[email protected]
    Feb 2024
    17
    I think it won't make boost because something is cutting power to the engine. did you see the video? it downshifts to go and its like the engine is in limp mode. turbo starts to spool then engine power cut and turbo stops spooling., thanks for your help bro.
    5BA8
    3,445
    Quote Originally Posted by colin7761 View Post
    Unless you're logging incorrect pids, the throttle blade is wide open, it looks like you have enough fuel and the spark timing is in the mid teens. That's about all you need to know.
    In your log the MAP pressure drops below 90 Kpa at WOT which would suggest there's an actual obstruction in the intake as opposed to a boost leak, where if that were the case you'd most likely see SOME boost before it falls off.
    I'd be checking all your piping, check your turbos, make sure they spin freely, etc.
    5BA8
    3,445
    The more I look at that data log the more it looks to me like the turbo is seized. The MAP pressure peaks at 98 Kpa at 3100 rpm and then falls off pretty quick and hard and continues to drop as long as you're WOT. The way the MAP pressure drops resembles an exhaust restriction. Like a turbo that won't spin.
    It would also, definitely feel like something is "holding it back".
    Mar 2009
    S. Florida
    582
    Set MAX MAP in Eng diagnostics to 200
    Feb 2024
    17
    i appreciate your help bro, is it possible an intercooler 90 elbow is collapsing on itself in the intercooler piping?
    5BA8
    3,445
    Quote Originally Posted by coanan View Post
    Has nothing to do with the current problem. He isn't even exceeding 100 Kpa.
    A silicone elbow isn't going to collapse on itself when you're trying to go into boost. The added pressure should keep it from collapsing. Now, if it's already collapsed, pinched real bad, etc. that would be different.
    Need to go check the vehicle over real well. Start by making sure the turbo wheel spins freely. Something is acting like a big plug in the system.
    Feb 2024
    17
    The turbo is spinning. I appreciate everyones help! I think i found the issue, it appears the intercooler piping is restricting the flow, some of the 90s were collapsing. I ran a test drive without the IC piping attached to throttle body and this time, there was no power loss. So thanks for the help!
    Jul 2022
    36
    Post
    That is good news, you could try shoving a cut piece of leftover intercooler pipe into the bends to support them from collapsing to test it (not the bend in front of the TB of course, don't want it sucked in). It looks like you have 2.5" piping and a honda size intercooler - not ideal but should still work; 3" IC piping and a 31"x12"x3" intercooler would work better.
    You should definitely hook up a boost leak tester @ ~10psi to the turbo inlet and check/fix leaks. The EGR valve will leak, and the EGR tube to the intake manifold seal will leak. I RTV'd the tube to intake manifold seal, and cut off/crushed/welded the tube portion that enters the intake manifold to eliminate leaks. Also, you will probably want to gap the plugs down from stock to ~.025 or .030 to prevent misfires.
    I attached a revised file mapped out to 2.2Bar just in case of overboost, as I didn't see you had a 2.25bar MAP sensor, and just minor other tweaks but everything looks pretty dialed in. Just check the edits of course, and definitely monitor AFR.
    What size turbo is on it?
    Sep 2021
    14
    So you turn sensed map off completely? What is the advantage of it off vs on?
