Results 1 to 8 of 8
Thread: Zo6 M7 shifting lag when trying to shift quickly
    Sep 2016
    27
    All,
    Any insight as to when I try to quickly shift the car through the gears there is a 1-3 second lag where the throttle acts like its closed even though the accelerator is to the floor? I plan on doing some 1/4 mile racing and this will kill my ET. Seems to be a torque management function GM has in there??? I just want to perform transitional lift and quick shifts like in my C6Z but this C7Z just won't let me....
    Dec 2015
    Miami,Fl.
    292
    Quote Originally Posted by N/A Zo6 View Post
    All,
    Are you activating the no lift shift feature? Maybe you're shifting too close to redline.
    2023 Ford Maverick 2.0T AWD
    Sep 2016
    27
    Quote Originally Posted by HeavyChevy305 View Post
    No, not using NLS and even tried shifting around 6300rpm and still did it. I have heard of guys experiencing this same issue just not sure what the solution is HPTUNER wise. Maybe deactivating the No lift shift feature by entering 250 mph vs the 31 mph stock setting.?
    May 2003
    South FL
    1,378
    Does it do it when you have traction control turned off or if the car is in Sport 1, Sport 2 or Race?
    [email protected]
    Owner/GM Calibrator
    Sep 2016
    27
    I tried it in Tour, sport and track. Does it in all (3) modes. I plan on taking it out today and logging a 2-3 hard shift and see whats going on. I'm guess virtual torque settings but not sure. I am new to the C7 platform I am used to the C6 stuff.
    May 2003
    South FL
    1,378
    None of those modes are Competition Mode with Sport 1, Sport 2 or Race. Meaning traction control is set to its most aggressive and will pull the throttle on hard shifts. Hitting the rev limiter after pushing in the clutch because you didn't come off the gas fast enough will feel the same way since there is a Histories RPM value in the OEM tune.
    You can either press the traction control button once to disable and then test hard shifts. Or you can try Competition Mode and set to Sport 1 or Sport 2. Race mode will fully disable the traction control. If this solves your problem then you are running into a traction control limit. If this does not solve your problem then you are hitting the rev limit without realizing.
    [email protected]
    Owner/GM Calibrator
    Nov 2009
    All Around
    3,149
    i have seen this happen when you activate the rev match feature
    Dec 2015
    Miami,Fl.
    292
    Activate NLS and hold down the traction control button for 5/10 seconds. That's what I do and have no issues. Hold on tight though if you're on stock tires.
