Results 1 to 19 of 19
Thread: Trying to adjust cam angles and they wont move from 133.5
    Mar 2019
    MS
    78
    Have the exhaust advanced to 134 and then start giving it back to intake at 4800 but in the logs its stuck at 133.5....Comp 270 cam with a limiter in it...Im trying to fix this tune for a friend...It had the exhaust disabled??? Any help greatly appreciated
    Is it a 0 degree lockout? Was it disabled from factory?
    Enable exhaust and change the numbers in the exhaust WOT table. Reduce them to retard the cam. 134 is home position.
    Mar 2018
    Illinois
    873
    BTW nothing you can do to move the cam at idle. You sure a limiter and not a locker was installed?
    Mar 2019
    MS
    78
    Quote Originally Posted by Homer View Post
    THATS what im waiting to find out...Had another friend ask the same question last night... When I got into it the stock 392 tables were in with the exhaust and phaser disabled and I was like WTF... On the logs they never moved after I turned them on so he might have a locker and not a phaser...
    Mar 2019
    MS
    78
    Nope motor blew at 130k because the lifters shit out and he had it rebuilt...New everything and a 270 cam...He has known something is wrong because I put buses on him with the same motor...
    Mar 2019
    MS
    78
    He was told a limiter
    Nov 2009
    All Around
    3,149
    besides the cam settings, which will not have other cars put buses on him. whats your fueling and ignition doing as it could have very low ignition with a build motor and knock sensors over active
    post a log
    Mar 2018
    Illinois
    873
    You said it had the exhaust disabled...on my 5.7 JGC it showed the VVT switches disabled but the cam was moving. Could it be when you enabled it you actually turned it off?
    2013 jeep stock (original).hpt
    Mar 2019
    MS
    78
    Nope this is before I touched it...same after I turned it on...
    This is a 392 300M
    Mar 2019
    MS
    78
    Quote Originally Posted by SultanHassanMasTuning View Post
    post a log
    Changing the cam settings in mine gives me 460lb #'s starting at around 2100 rpm all the way through to intersection where his is low 300's and peaks at 400 at intersection, so yeah I put buses on him from the get go.... Adjusting the numbers gave me 50ft# easy...I learned that through help on here and showed my original tuner when he ran it on the dyno to check the difference. Mine is cammed with a Apache Max
    None of the tune is mine except the commanded cam timing I put in...Im just trying to help...Im giving him my cat deletes with a extra WB bung in and I will check his AF when that happens...Next couple of days...
    I had a 2012 300 that from factory had some of the tables set to disable. Basically had to switch them to the opposite to make it work.. exhaust and the main switches for vct
    Mar 2019
    MS
    78
    Quote Originally Posted by luciddeath View Post
    Aint that some shit...I turned on and adjusted tables...Ok, I will turn both back off and see if it actually works...Thanks man! Hopefully I can get the WB in today to see where he is at...
    Mar 2019
    MS
    78
    Quote Originally Posted by Party340 View Post
    We have 392's unboosted with cams....You advanced the exhaust till about intersection and then start retarding it to give back to the intake
    Mar 2018
    Illinois
    873
    Quote Originally Posted by ShannonSRT View Post
    Isn't that what I showed you in post#9 but you said it wasn't it?
    Mar 2019
    MS
    78
    Just was told by the builder no locker OR phaser was installed with the 270 cam...He said all of it was turned off and its just running on springs? WTF
    Mar 2018
    Illinois
    873
    Sounds like a broken change machine....makes no cents.
    Mar 2019
    MS
    78
    lol so now im glad I wasn't able to move anything... I guess he used someone who knew nothing about them...I don't know where to go from here
    818
    Compare the 270 to the stock 392 cam.
