Results 1 to 6 of 6
Thread: Need Transmission Layout foer TCC Slip & Duty Cycle
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    532
    Can I get An Opinion On MY TCC Slip Scan?
    Bumping this up? Updated.
    Russ if you are reading, earlier you said to find out and I took her in and got a suggested service (it was time mileage wise) and they stopped but they are back now and more often.
    I took it back in and they promptly told me I needed a new trans! The statement was, "My trans guy says he has seen this code before and it will not be long before it stops pulling". He quoted me $3500.00 for a re-man trans. I got my car the hell out of there. No way they had time to check the harness and such much less no description of the worn part(s) or issue.
    I have her at another shop for another opinion, they will actually run tests. The tech is supposed to be very reputable and experienced. He looks it over tomorrow.
    I have no idea what is acceptable slip or not. I made the attached log today, it starts off me sitting at a light and I eventually get her up to speeds and hold her there at different MPH's.
    I have to play it back @0.2x to follow. You guys should be able to tell pretty early in the log.
    Is the slip excessive? Thanks
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    You need to diagnose why the TCC is stuck on.
    Russ Kemp
    Jun 2009
    N. GA
    532
    Bump!!!!
    Where is the tune? and are there codes?
    Jun 2009
    N. GA
    532
    Quote Originally Posted by Kmoney View Post
    P0741 TCC Circuit Performance or stuck Open. Tune attached but did you see the scan?
    Jun 2009
    N. GA
    532
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    Thanks, I will finally get around to doing this this weekend. I sure would like to hear opinions on my scan however.
