Results 1 to 13 of 13
Thread: PIDS
    Guest
    Guest
    PIDS
    PID LIST BELOW
    MORE TO COME LATER THERE ARE AROUND 247 TOTAL PIDS COMING SOON.
    Sep 2002
    Chicago, IL
    6,397
    Re: PIDS
    Kick ass.. some ford info.
    We got this guy Not Sure, ...
    Tuner in Training jfunk's Avatar
    Apr 2003
    San Diego
    46
    Re: PIDS
    I have an offical repair manual on CD that the Ford technicians use to repair the cars and it has some PIDs and DTCs on it. I don't think that it lists all of the PIDs and DTCs though. I've noticed that some of the PIDs have some sort of extended addresses like the ones below.
    [Acronym] / [PID #] / [Description] / [Ford Units]
    4X4L / 1101 b2 / Requested 4 Wheel Drive Input / ON/OFF
    ACCS / 1101 b0 / Air Conditioning Cycling Switch Input / ON/OFF
    BPP/BOO / 1101 b1 / Brake Pedal Position/Brake On-Off Switch Input / ON/OFF
    CPP/PNP / 1101 b3 / Neutral Position Switch Input / ON/OFF
    2000 Ford Focus SE
    Guest
    Guest
    Re: PIDS
    ATTENTION: IM NOT SURE IF ALL OF THESE PIDS ARE ACCURATE.
    PID PID NAME
    1101 4X4L-REQUESTED 4 WHEEL DRIVE INPUT LOW SWITCH
    1113 ABA-SECONDARY AIR BYPASS ACTUAL
    1113 ADA-SECONDARY AIR DIVERTER ACTUAL
    1101 ACCS-AIR CONDITIONING CLUTCH CYCLING SWITCH INPUT
    1102 ACP-A/C HEAD PRESSURE SWITCH INPUT
    1667 ACPM-A/C HEAD MEDIUM PRESSURE SWITCH INPUT
    1686 ACPP-A/C HEAD PRESSURE SWITCH INPUT PRESSURE
    1638 ACPV-A/C HEAD PRESSURE SWITCH INPUT VOLTAGE
    163E AFBIAS1-AIR/FUEL RATIO BIAS FROM IDEAL BANK 1
    163E AFBIAS2-AIR/FUEL RATIO BIAS FROM IDEAL BANK 2
    1104 AIR-SECONDARY AIR PUMP CONTROL
    110E AIRA-SECONDARY AIR INJECTION CIRCUIT MONITOR
    1688 AIRB-SECONDARY AIR INJECTION BYPASS
    1688 AIRD-SECONDARY AIR INJECTION DIVERT
    162F AIRF-SECONDARY AIR OUTPUT FAULT INDICATOR
    110C AIRM-SECONDARY AIR INJECTION MONITOR
    1340 AP-ACCELERATOR PEDAL POSITION PERCENT
    1340 APV-ACCELERATOR PEDAL POSITION VOLTS
    1104 ARC-AUTOMATIC RIDE CONTROL STATUS
    1127 BARO-BAROMETRIC PRESSURE INCHES OF MERCURY
    1127 BAROF-BAROMETRIC PRESSURE HERTZ
    1442 BAROP-BAROMETRIC PRESSURE PSI
    114B BAROV-BAROMETRIC PRESSURE VOLTAGE
    1681 BLWMTR-HEATER BLOWER MOTOR INPUT
    A211 BPA-BRAKE PRESSURE APPLIED SWITCH
    1101 BPP/BOO-BRAKE PEDAL POSITION/BRAKE ON-OFF SWITCH
    16CF CAMDCR-COMMANDED DUTY CYCLE FOR VCT SOLENOID PERCENT
    16CE CAMERR-VARIABLE CAMSHAFT TIMING ERROR IN CRANKSHAFT DEGREES
    16C0 CASGND-PCM CASE GROUND VOLTAGE
    1609 CATCAL1-AVERAGE CALIBRATED TEST FREQUENCY FOR BANK 1 CATALYST EFFICIENCY HERTZ
    160A CATCAL2-AVERAGE CALIBRATED TEST FREQUENCY FOR BANK 2 CATALYST EFFICIENCY HERTZ
    1128 CATTST1-TEST FREQUENCY FOR BANK 1 CATALYST HERTZ
    1129 CATTST2-TEST FREQUENCY FOR BANK 2 CATALYST HERTZ
    1105 CCS-COAST CLUTCH SWITCH SOLENOID CIRCUIT COMMANDED
    1107 CCSA-COAST CLUTCH SOLENOID CIRCUIT MONITOR IS HIGH
    16CA CCSDC-COAST CLUTCH SOLENOID OUTPUT DUTY CYCLE PERCENT
    1682 CCSC-CURRENT MONITOR FOR 3-2 TIMING COAST CLUTCH SOLENOID MILLIAMPS
    16BE CCSF-COAST CLUTCH SOLENOID INDUCTIVE SIGNATURE MALFUNCTION
    1682 CCSP-PRESSURE REQUIRED FOR 3-2 TIMING COAST CLUTCH SOLENOID
    1683 CCSV-COAST CLUTCH SWITCH SOLENOID 302 CIRCUIT VOLTS
    A211 CCP-CLUTCH PEDAL POSITION TRANSMISSION CONTROL SWITCH
    1624 CHT-CYLINDER HEAD TEMPERATURE INPU DEGREES F
    1685 CHTV-CYLINDER HEAD TEMPERATURE INPUT VOLTS
    1688 CHTIL-CYLINDER HEAD TEMPERATURE INDICATOR LAMP
    1688 CHTILF-CYLINDER HEAD TEMPERATURE INDICATOR LAMP FUALT
    1107 CMPFM-CAMSHAFT POSITION SENSOR FAILURE MODE
    1101 CPP/PNP-CLUTCH PEDAL/PARK NEUTRAL POSITION SWITCH INPUT
    1681 CRUISE-CRUISE MODE
    160D DOL-DATA OUTPUT LINK TO TRIP COMPUTER FUEL CONSUMPTION
    114E DPFEGR-DIFFERENTIAL PRESSURE FEEDBACK EGR INPUT
    1688 DPI-SECONDARY SPARK PLUGS ENABLED
    1681 DRLMP-DAYTIME RUNNING LAMP INPUT
    0101 DRNECT-NUMBER OF OBD2 DRIVE CYCLES COMPLETED
    0200 DTCCNT-CONTINUIOUS DTC COUNTER
    1445 EBPA-EXHAUST BACK PRESSURE ABSOLUTE PSI
    16AE EBPV-EXHAUST BACK PRESSURE SENSOR VOLTAGE
    1139 ECT-ENGINE COOLANT TEMPERATURE INPUT DEGREE F
    114D ECTV-ENGINE COOLANT TEMPERATURE INPUT VOLTAGE
    1602 ECTFIL-ENGINE COOLANT TEPERATURE FAULT FILTER MXIMUM
    168E EFTA-ENGINE FUEL TEMPERATURE BANK 1 INPUT VOLTS
    168D EFTAV-ENGINE FUEL TEMPERATURE BANK 2 INPUT DEGREE F
    1690 EFTB-ENGINE FUEL TEMPERATURE BANK 2 INPUT DEGREE F
    168F EFTBV-ENGINE FUEL TEMPERATURE BANK 2 INPUT VOLTS
    167D EGRC-VACCUM SOLENOID OPEN(ON) TO INTAKE (OPEN EGR)
    167D EGRV-VENT SOLENOID OPEN(OFF) TO ATMOSPHERE (CLOSE EGR)
    167D EGRBARO-ENABLE BAROMETER INSTEAD OF EGR PRESSURE SENSOR
    167D EGRCF-EGR VALVE VACUUM SOLENOID OUTPUT FAULT DETECTED
    167D EGRVF-EGR VALVE VENT SOLENOID OUTPUT FAULT DETECTED
    167D EGRBARF-EGR PRESSURE OUTPUT SENSOR METHOD FAULT DETECTED
    167E EGRVP-EGR VALVE POSITION VOLTAGE
    167F EGRVPD-EGR VALVE POSITION DESIRED VOLTAGE
    113C EGRVR-EGR VALVE VACUUM REGULATOR CONTROL PERCENT
    163D EGRVRA-EGR VALVE VACUUM REGULATOR CONTROL ACTUAL VOLTS
    162E EGRVRF-EGR OUTPUT FAULT DETECTED
    1310 EOT-ENGINE OIL TEMPERATURE SENSOR INPUT DEGREE F
    16AF EOTV-ENGINE OIL TEMPERATURE SENSOR INPUT VOLTS
    16A9 EOTF-ENGINE OIL TEMPERATURE SENSOR FAULT DETECTION
    11C0 EPC-TRANSMISSION LINE ELECTRONIC PRESSURE CONTROL PSI
    11B2 EPCV-TRANSMISSION LINE ELECTRONIC PRESSURE CONTROL VOLTS
    16D0 EPCDC-COMMANDED DUTY CYCLE ELECTRONIC PRESSURE CONTROL SOLENOID PERCENT
    1433 EPR-EXHAUST BACK PRESSURE REGULATOR DUTY CYCLE PERCENT
    162F EVAPCPF-EVAPORATIVE EMISSIONS CANISTER PURGE OUTPUT FAULT DETECTED
    1167 EVAPCV-EVAPORATIVE EMISSION CANISTER PURGE VENT CONTROL PERCENT
    1103 EVAPCVA-EVAPORATIVE CANISTER VAPOR MANAGEMENT VALVE FAULT DETECTED
    1630 EVAPCVF-EVAPORATIVE EMISSIONS CANISTER PURGE VENT FAULT
    1166 EVAPPDC-EVAPORATIVE EMISSIONS CANISTER PURGE DUTY CYCLE CONTROL PERCENT
    1627 EVAPPF-EVAPORATIVE PURGE FLOW INPUT VOLTS
    1636 EVAPVMA-EVAPORATIVE VAPOR MANAGEMENT VALVE INTERNAL CIRCUIT MONITOR VOLTS
    110C FANM-LOW SPEED FAN MONITOR
    16AB FF-FLEX FUEL SENSOR INPUT FREQUENCY HZ
    16C1 FLI-FUEL LEVEL INDICATOR INPUT PERCENT
    16BF FLIV-FUEL LEVEL INDICATOR INPUT VOLTAGE
    1672 FP-FUEL PUMP DUTY CYCLE PERCENT
    110E FPA-FUEL PUMP CONTROL PRIMARY CIRCUIT MONITOR
    1673 FPMR-FUEL PUMP SECONDARY MONITOR HI/LOW TIME RAITO
    162E FPF-FUEL PUMP OUTPUT FAULT
    110C FPM-FUEL PUMP SECONDARY MONITOR
    167D FPRC-FUEL PRESSURE REGULATOR VENTED TO ATMOSPERE
    167D FPRCF-FUEL PUMP REGULATOR CONTROL FAULT
    168C FRP-ENGINE INJECTOR PRESSURE INPUT PSI
    110C FRPV-ENGINE INJECTOR PRESSURE INPUT VOLTS
    1691 FSV-ENGINE FUEL SOLENOID VALVE
    1691 FSVF-ENGINE FUEL SOLENOID VALVE FAULT
    1691 FSVM-ENGINE FUEL SOLENOID VALVE SECONDARY MONITOR
    1687 FTP-FUEL TANK PRESSURE INPUT
    1639 FTPV-FUEL TANK PRESSURE INPUT VOLTS
    1410 FUELPW-FUEL INJECTOR PULSE TIME
    1141 FUELPW1-INJECTOR PULSE WIDTH BANK 1 TIME
    1142 FUELPW2-INJECTOR PULSE WIDTH BANK2 TIME
    11B3 GEAR-TRANSIMISSION GEAR STATUS NUMBER
    0927 GENF-GENERATOR OUTPUT FAULT DETECTION
    16E8 GENFDC-GENERATOR FIELD CONTROL OUTPUT PERCENT
    0939 GFS-GENERATOR FIELD SIGNAL MONITOR PERCENT
    1667 GP-GLOW PLUGS
    1430 GPC-GLOW PLUG CONTROL PERCENT
    1450 GPCT-GLOW PLUG CONTROL TIME
    1451 GPLT-GLOW PLUG LAMP TIME
    1681 HDLMP-HEADLAMP INPUT
    1103 HFC-HIGH SPEED FAN CONTROL
    110E HFCA-HIGH SPEED FAN CONTROL PRIMARY CIRCUIT MONITOR
    162F HFCF-HIGH SPEED FAN CONTROL FAULT
    1631 HTR11-BANK 1 UPSTREAM O2S HEATER CONTROL
    110C HTR11A-BANK 1 UPSTREAM O2S HEATER CONTROL PRIMARY CIRCUIT MONITOR
    1679 HTR11C-BANK 1 UPSTREAM O2S HEATER CURRENT MONITOR MILLIAMPS
    1605 HTRCT-BANK 1 UPSTREAM OXYGEN SENSOR HEATER RETRIES
    1631 HTR11F-BANK 1 UPSTREAM O2S HEATER CIRCUIT FAULT
    1631 HTR12-BANK 1 DOWNSTREAM O2S HEATER CONTROL
    110C HTR12A- O2S HEATER CONTROL PRIMARY CIRCUIT MONITOR
    167A HTR12C-BANK 1 DOWNSTREAM O2S HEATER CURRENT MONITOR MILLIAMPS
    1606 HTR12CT-BANK 1 DOWNSTREAM OXYGEN SENSOR HEATER RETRIES
    1631 HTR12F-BANK1DOWNSTREAM O2S HEATER CIRCUIT FAULT
    1631 HTR21-BANK 2 UPSTRAM O2S HEATER CONTROL
    110C HTR21A-OXYGEN SENSOR HEATER CONTROL PRIMARY CIRCUIT MONITOR
    167B HTR21C-BANK 2 UPSTREAM OXYGEN SENSOR HEATER CURRENT MONITOR MILLIAMPS
    1607 HTR21CT-BANK 2 UPSTREAM OXYGEN SENSOR HEATER RETRIES
    1631 HTR21F-BANK 2 UPSTREAM O2S HEATER CIRCUIT FAULT
    1631 HTR22-BANK 2 DOWNSTREAM O2S HEATER CONTROL
    110C HTR22A-O2S HEATER CONTROL PRIMARY CIRCUIT MONITOR
    167C HTR22C-BANK 2 DOWNSTREAM O2S HEATER CURRENT MONITOR MILLIAMP
    1608 HTR22CT-BANK 2 DOWNSTREAM O2S HEATER RETRIES
    1631 HTR22F-BANK 2 DOWNSTREAM O2S HEATER CIRCUIT FAULT
    1102 HTRX1-O2S UPSTREAM HEATER CONTROL
    1102 HTRX2-O2S DOWNSTREAM HEATER CONTROL
    162E IACF-IDLE AIR CONTROL OUPUT FAULT DETECTED
    1153 IAC-IDLE AIR CONTROL PERCENT
    1123 IAT-INTAKE AIR TEMPERATURE INPUT DEGREE F
    114A IATV-INTAKE AIR TEMPERATURE INPUT VOLTS
    16A8 IAT2-INTAKE AIR TEMPERATURE SENSOR 2 INPUT DEGREE F
    16A7 IAT2V-INTAKE AIR TEMPERATURE SENSOR 2 INPUT VOLTS
    1601 IATCNT-INTAKE AIR INTERMITTENT FAULT FILTER MAXIMUM
    1446 ICPA-INJECTOR CONTROL PRESSURE ABSOLUTE PSI
    1103 IMRC-INTAKE MANIFOLD RUNNER CONTROL
    162F IMRCF-INTAKE MANIFOLD RUNNER CONTROL FAULT
    1634 IMRCM-INTAKE MANIFOLD RUNNER CONTROL MONITOR INPUT BANK 1 VOLTS
    1635 IMRC2M-INTAKE MANIFOLD RUNNER CONTROL MONITOR INPUT BANK2 VOLTS
    1684 IMTV-INTAKE MANIFOLD TUNING VALVE CONTROL PERCENT
    162F IMTVF-INTAKE MANIFOLD TUNING VALVE FAULT
    162D INJ1F-FUEL INJECTOR 1 PRIMARY FAULT
    162D INJ2F-FUEL INJECTOR 2 PRIMARY FAULT
    162D INJ3F-FUEL INJECTOR 3 PRIMARY FAULT
    162D INJ4F-FUEL INJECTOR 4 PRIMARY FAULT
    162D INJ5F-FUEL INJECTOR 5 PRIMARY FAULT
    162D INJ6F-FUEL INJECTOR 6 PRIMARY FAULT
    162D INJ7F-FUEL INJECTOR7 PRIMARY FAULT
    162D INJ8F-FUEL INJECTOR 8 PRIMARY FAULT
    16EA INJ9F-FUEL INJECTOR 9 PRIMARY FAULT
    16EA INJ10F-FUEL INJECTOR 10 PRIMARY FAULT
    1698 INJ1M-FUEL INJECTOR 1 COMMANDED MODE
    1698 INJ2M-FUEL INJECTOR 2 COMMANDED MODE
    1698 INJ3M-FUEL INJECTOR 3 COMMANDED MODE
    1698 INJ4M-FUEL INJECTOR 4 COMMANDED MODE
    1698 INJ5M-FUEL INJECTOR 5 COMMANDED MODE
    1698 INJ6M-FUEL INJECTOR 6 COMMANDED MODE
    1434 IPR-INJECTION CONTROL PRESSURE DUTY CYCLE PERCENT
    16E6 KS1V-KNOCK SENSOR INPUT BANK 1 VOLTS
    16E7 KS2V-KNOCK SENSOR INPUT BANK 2 VOLTS
    110E LFCA-LOW SPEED FAN CONTROL PRIMARY CIRCUIT MONITOR
    1103 LFC-LOW SPEED FAN CONTROL
    162F LFCF-LOW SPEED FAN CONTROL FAULT
    1688 LFP-LOW SPEED FUEL PUMP
    115A LOAD-CALCULATED ENGINE LOAD PERCENT
    1103 LOOP-FEEDBACK FUEL CONTROL STATUS
    1156 LONGFT1-LONG TERM FUEL TRIM BANK 1
    1157 LONGFT2-LONG TERF FUEL TRIM BANK2
    1671 MAF-MASS AIRFLOW RATE INPUT LB/MIN
    1177 MAFV-MASS AIRFLOW RATE VOLTS
    1633 MAFV-MASS AIRFLOW RATE INPUT VOLTS (THIS IS NOT A RETYPE)
    1440 MAP-MANIFOLD ABSOLUTE PRESSURE PSI
    1412 MFDES-MASS FUEL DESIRED MILLIGRAM
    1103 MIL-MALFUNCTION INDICATOR LAMP CONTROL
    162E MILF-MALFUNCTION INDICATOR LAMP OUTPUT FAULT
    1102 MISF-ENGINE MISFIRE STATUS
    1102 OCTADJ-OCTANE ADJUST STATUS
    16EF OCTADJS-OCTANE ADJUST SOFTWARE STATUS
    1173 O2S11-BANK 1 UPSTREAM O2S INPUT VOLTAGE
    1174 O2S12-BANK 1 DOWNSTREAM O2S INPUT VOLTAGE
    1175 O2S21-BANK 2 UPSTREAM O2S INPUT VOLTAGE
    1176 O2S22 BANK 2 DOWNSTREAM O2S INPUT VOLTAGE
    1695 O2S11C-BANK 1 UPSTREAM O2S BEFORE DOWN SHIFT CORRECTION VOLTAGE
    1699 O2S12C-BANK 1 DOWNSTREAM O2S BEFORE DOWN SHIFT CORRECTION VOLTAGE
    1696 O2S21C-BANK 2 UPSTREAM O2S BEFORE DOWN SHIFT CORRECTION VOLTAGE
    169A O2S22C-BANK 2 DOWNSTREAM O2S BEFORE DOWN SHIFT CORRECTION VOLTAGE
    11B5 OSS-TRANSMISSION OUTPUT SHAFT SPEED RPM
    A211 PBA-PARKING BRAKE APPLIED SWITCH
    0951 PERDEL1-MISFIRE CYLINDER 1 PERCENT DELTA
    0952 PERDEL1-MISFIRE CYLINDER 2 PERCENT DELTA
    0953 PERDEL1-MISFIRE CYLINDER 3 PERCENT DELTA
    0954 PERDEL1-MISFIRE CYLINDER 4 PERCENT DELTA
    0955 PERDEL1-MISFIRE CYLINDER 5 PERCENT DELTA
    0956 PERDEL1-MISFIRE CYLINDER 6 PERCENT DELTA
    0957 PERDEL1-MISFIRE CYLINDER 7 PERCENT DELTA
    0958 PERDEL1-MISFIRE CYLINDER 8 PERCENT DELTA
    1627 PF-REQUESTED EVAPORATIVE PURGE FLOW SENSOR VOLTAGE
    1102 PIP-PROFILE IGNITION PICKUP INPUT
    1101 PNP-PARK NEUTRAL SWITCH
    1101 PSP-POWER STEERING PRESSURE SWITCH INPUT LOAD PRESENT
    1626 PSPV-POWER STEERING PRESSURE INPUT VOLTAGE
    1625 PSPV-POWER STEERING PRESSURE TRANSDUCER INPUT
    160D PTO-POWER TAKE OFF STATUS INPUT
    16CD RCAM-VCT SOLENOID COMMANDED IN CRANK SHAFT DEGREES
    1681 RDEF-REAR WINDOW ELECTRIC DEFROST INPUT
    9999 VERIFY-RELEASE AND BUILD MODE
    1697 REV-TRANSMISSION REVERSE SWITCH INPUT
    1165 RPM-ENGINE SPEED BASED ON CKP INPUT
    0964 SCB-SUPERCHARGER BYPASS CONTROL
    0964 SCBF-SUPERCHARGER BYPASS CONTROL FAULT
    0964 SCICP-SUPERCHARGER INTERCOOLER PUMP CONTROL
    0964 SCICPF-SUPERCHARGER INTERCOOLER PUMP CONTROL FAULT
    1158 SHRTFT1-CURRENT BANK 1 FUEL TRIM ADJUSTMENT FROM STOICHIOMETRY SHORT TERM
    1159 SHRTFT2-CURRENT BANK 2 FUEL TRIM ADJUSTMENT FROM STOICHIOMETRY SHORT TERM
    116B SPARKADV-DESIRED IGNITION SPARK TIMING DEGREES
    1105 SS1-SHIFT SOLENOID 1 CONTROL
    1632 SS1-SHIFT SOLENOID 1 CONTROL FAULT
    1105 SS1-SHIFT SOLENOID 2 CONTROL
    1632 SS1-SHIFT SOLENOID 2 CONTROL FAULT
    1106 SS1-SHIFT SOLENOID 3 CONTROL
    1632 SS1-SHIFT SOLENOID 3 CONTROL FAULT
    162F TATCF-SECONDARY THROTTLE (TRACTION CONTROL) OUTPUT FAULT DETECTED
    11B0 TCC-TORQUE CONVERTER CLUTCH CONTROL PERCENT
    110E TCCA-TORQUE CONVERTER CLUTCH CONTROL INTERNAL CIRCUIT MONITOR
    1632 TCCF-TORQUE CONVERTER CLUTCH OUTPUT FAULT
    1104 TCIL-TRANSMISSION CONTROL INDICATOR LAMP CLUTCH CONTROL STATUS
    1101 TCS-TRANSMISSION CLUTCH CONVERTER CONTROL SWITCH INPUT
    162A TCTC-REQUESTED TRACTION ASSIST DUTY CYCLE PERCENT
    1674 TFT-TRANSMISSION FLUID TEMPERATURE INPUT DEGREE F
    11BD TFTV-TRANSMISSION FLUID TEMPERATURE INPUT VOLTAGE
    2214 TORQUE-NET ENGINE TORQUE FTLBS
    1125 TPMODE-THROTTLE POSITION MODE
    1154 TPV-THROTTLE POSITION(FUEL LEVER DIESEL) INPUT VOLTAGE
    1629 TPB-SECONDARY THROTTLE POSITION INPUT VOLTAGE
    1169 TPREL-LOWEST STEADY TP VOLTAGE SINCE ENGINE START VOLTAGE
    11B6 TR-TRANSMISSION SELECTOR POSITION INPUT STATUS
    1104 TRACUNL-TRACTION CONTROL CONVERTER UNLOCKED
    1151 TRV-TRANSMISSION SELECTOR POSITION INPUT STATUS VOLTAGE
    16B5 TRD-TRANSMISSION SELECTOR POSITION INPUT STATUS (DIGITAL)
    1103 TRIP-OBD II TRIP COMPLETE
    0100 TRIPCT-NUMBER OF COMPLETED OBD II TRIPS
    11B4 TSS/ISS-TURBINE SHAFT SPEED/INPUT SHAFT SPEED
    16B1 VCTA-VARIABLE CAMSHAFT TIMING CONTROL CIRCUIT MONITOR
    16B1 VCTENA-CONDITIONS CORRECT TO ENABLE VARIABLE CAMSHAFT TIMING CONTROL
    16AA VFC-VARIABLE FAN CONTROL ON PERCENT
    1411 VFDES-VOLUME FUEL DESIRED CUBIC MM
    1172 VPWR-VEHICLE POWER BATTERY VOLTAGE
    1155 VREF-VEHICLE REFERENCE CALIBRATION VOLTAGE INPUT
    11C1 VSS-VEHICLE SPEED SENSOR MPH
    1604 VSFIL-VEHICLE SPEED SENSOR FAULT FILTER MAXIMUM
    A210 VSSET-VEHICLE SPEED SETTING MPH
    1104 WAC-WOT RELAY STATUS FOR A/C CLUTCH CONTROL
    110E WACA-WAC RELAY CONTROL PRIMARY CIRCUIT MONITOR
    162E WACF-WOT A/C PRIMARY CIRCUIT FAULT
    16E1 WGC-WASTE GATE CONTROL PERCENT
    I NEED THE FORMULAS TO DETERMINE WHAT THE RECEIVE DATA MEAN!! THIS WILL TAKE A WHILE TO FIGURE THEM OUT
    Guest
    Guest
    Re: PIDS
    I finally registered. Sorry i can not delete the first message(no need for that). i hope u can fix that webmaster.
    Sep 2002
    Chicago, IL
    6,397
    Re: PIDS
    Fixed. Thanks for the information.
    Re: PIDS
    good info!!
    Business Network Solutions - for all your PC, network, printer and computer security needs.
    Jul 2003
    3
    Re: PIDS
    I used Comlite software to watch the data on the OBDSCAN Program that retreives enhance data.
    Jul 2003
    10
    Re: PIDS
    Quote Originally Posted by DATAMAN2
    Can you also post the unit of measurement for each one if you have it?
    Jul 2003
    3
    Re: PIDS
    Disasm...on my spare time I will try my best to add the units to the list.
    Apr 2003
    San Diego
    46
    Re: PIDS
    Quote Originally Posted by disasm
    I can list around 200 PIDs with the unit of measurement(Less work for DATAMAN2). All I have to do is Cut & Paste.
    2000 Ford Focus SE
    Jul 2003
    3
    Re: PIDS
    Thanks Jfunk. That will be awesome if u can help out with the units.
    Apr 2003
    San Diego
    46
    Re: PIDS
    2000 Ford Focus SE
Similar Threads
  1. What PIDs to log for MAF tuning/Scaling?
    By radkon in forum VCM Scanner
    Last Post: 09-17-2007, 01:08 PM
  2. Trans PID's
    By Galvatron in forum VCM Scanner
    Last Post: 06-04-2007, 07:58 AM
  3. Scan PIDS write up
    By 00GTP in forum GM V6 Tuning - Engine
    Last Post: 05-03-2006, 01:19 PM
  4. Idle PIDs in HPT not logging... any ideas?
    By Visceral in forum GM V8 Tuning - Engine, Gas (Gen 3)
    Last Post: 05-24-2005, 06:27 PM
  5. PID's Dissapear ....
    By EpOcH in forum VCM Scanner
    Last Post: 05-13-2005, 08:15 AM
