Results 1 to 7 of 7
Thread: LS swap starting PCM/Stock tune
    Is there any reason to start with a different base tune? What I mean is a 2000 stock tune verse a 2002 stock tune, etc... I just got HPtuners, I assume it can flash any tune on the p01 that it supports?
    Mar 2011
    Ripley, MS
    1,864
    Quote Originally Posted by DodgeZ View Post
    There can be several advantages. If I am working on a swap that requires a P01 computer, I'd start with the 2002 model OS...typically 12212156 OS.
    A couple of the primary advantages are that the e-fans will work properly on the later OS. (They won't work properly on some of the 99-00 model OS's.)
    It will also eliminate the secondary VE table that on the earlier OS.
    Nov 2006
    North Carolina
    4,846
    I agree, I'd shoot for a 2002 F body if your starting from scratch.
    Thanks! The PCM I have is a 2000, can HPtuners flash the 2002 12212156 OS on to it?
    405
    3,231
    Yes but it will require 4 credits. You always have to have a license for what is in the PCM and what you are writing to it. Usually what you are flashing is based off what was read so they are the same base files. In your case they would be different. So each would require a separate license. 2 credits each.
    Quote Originally Posted by 2xLS1 View Post
    Can you just flash the 12212156 OS over without buying the license for the stock 2000 OS? Seems odd to buy a license for an OS you aren't using. Can the 12212156 OS support flex fuel or is that different OS only? I am not sure what the segment swap stuff does. Thanks
    405
    3,231
    No and no. Well not with HP Tuners.
