Hi all,
Did a V8 swap to a 2011 Colorado from 2003 Suburban with current performance harness and computer programing. Motor operates fine but I cannot get transmission to engage any gear. ECM is E40 and TCM is T42. Transmission is from same junkyard suburban as the motor, did not see either run.
I put a new filter in transmission. I have overfilled the transmission to make sure the pump primed. Level seems to go down when running. if wheels are in the air they do seems to spin when in gear but slowly. On the ground it does not move at all when in R or D at idle or with RPM.
Scan with transmission channels attached, as well as tune. Anyone have any ideas ?
Thanks,
Joel
