Results 1 to 11 of 11
Thread: problem of reconstitution of the stock tune and activation of Flexfuel without sensor
    May 2022
    11
    Hi, I work on a 2015 Camaro SS (2014 model).
    The PCM has been strangely modified by a previous owner (e.g. adding burble but without DFCO modification)
    I'm having trouble reconstituting the original tune. The closest I could find in the tune repository is a 2010 tune camaro. I was surprised by the year difference.
    Can someone familiar with Camaros tell me if my corrections are correct?
    (I have also removed the torque limitations.)
    In addition I want to activate the flexfuel without sensor (we drive a lot on E85 in France) I searched quite a bit, looked at the different tabs, I think I did it correctly but the same, if someone could tell me if am I good?
    I attach the tune found in the pcm (tune read) and the one that I redid and modified (new tune)
    Thank you in advance for your help.
    Tuning Addict
    10,887
    'Virtual' flexfuel without the sensor does not work very well even in completely stock unmodified brand-new vehicles. Not recommended.
    May 2022
    11
    Ok, I see thread about the virtual flexfuel which is not very good on gm.
    But is there error in my tune if we don't look about flexfuel tables ? I can't reach to find a stock tune for this car.
    I have a 2012 and 2016 camaro file. (Believe they are from the repository)
    They both have flex fuel disabled. The 2016 looks to be a different OS.
    2012camaroa6.hpt
    2016camaro6.2auto.hpt
    I thought there was some way to add a physical sensor?
    I have a 2012 Tahoe that seems to adapt to e85 and back without any noticeable issues so far.. (virtual sensor)
    May 2022
    11
    Quote Originally Posted by mikez71 View Post
    2012camaroa6.hpt
    Have you the file of your Tahoe to compare with mine ? (To Check if I don't miss something lol)
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    359
    Turn all the flex fuel stuff off. Here is a 2013 file you can compare too, should be pretty close to what your car had stock.
    If you want to run flex fuel get this kit.
    https://dsxtuning.com/collections/fl...-camaro-ss-1le
    2013 CTS-V Coupe M6 - 2" Headers, 3" x-mid pipes, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSX flex fuel kit, DMS 2g under hood tank, ZZP pump, reinforced brick, 3/4" lines, AFCO HX, Griptec 2.4" pulley, solid isolator, 100mm idler, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq on e85
    Nov 2006
    North Carolina
    4,855
    Have you looked on the tune repository for a stock file?
    I'm fairly certain I would have one. You might have a export OS though compared to what I see here in the states.
    May 2022
    11
    I think it's very possible, maybe an European Version, that why I can't find a similar tune on the repository.
    I just find recently a 2013 tune on the Hptuner forum that look similar.
    I'm surprised by the rich/lean vs airflow table (oxygen sensor tab, ecm 12530 and 12531) with is often populated by all 450 values on tube found on repository and mine have value from 61 to 328....
    May 2022
    11
    Quote Originally Posted by JayRolla View Post
    Thanks for the link but it's for a friend who prefer flexfuel tune without sensor or a full e85 tune.
    And with delivery and tax, the price is around twice once arrived in France....
    Mar 2021
    359
    Quote Originally Posted by droops_18 View Post
    There is no reason to not to use the sensor. Even at double the price it's worth it.
    If he wants to do flex only just switch stoich table completely to e80 or whatever % you guys have. Don't use any flex fuel stuff and tune it like it's on gas. Just remember when the content percentages change the tune will go off. I have ran straight e85 tunes and would tune lambda on the highest content so if I got less it would run a bit richer.
    May 2022
    11
    Ii know I've this solution, that what I've made on my Chrysler and ram 5,7L which have no flexfuel capabilities before 2015
