Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Flex fuel sensor p59 reads 0% alcohol
    Jul 2022
    7
    Hello just installed a FF sensor to my 2004 silverado. I am running a p59 OS 12587603. Copied the flex fuel tables from a 2004 Tahoe. The problem im having is when i load up the scanner and add alcohol percent it read 0 never moves. I will put tune in here also. Can you someone look at tune and see if i did something wrong? Thanks!
    May 2014
    USA
    624
    try this one
    Jan 2015
    Arizona
    1,165
    Quote Originally Posted by pudman85 View Post
    Hello
    with the file name of blue waffle, id never open that file
    Jul 2022
    7
    Quote Originally Posted by bk2life View Post
    HAHA ya didnt think that threw lol
    Advanced Tuner abc's Avatar
    Jan 2024
    905
    I didn't even look at that part, LOL! I noticed the .hpt extension and just sent it, it's all good, meaning it is a proper .hpt file.
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    341
    Did you turn on the appropriate DTCs?
    Jul 2022
    7
    Quote Originally Posted by Pulse_GTO View Post
    No i did not. Wasnt aware that i needed to. Would you happen to know what ones i need to turn on. I will google it too. i have been tuning some gen 3 stuff for a couple years now but this is my first Flex fuel sensor. Thanks!
    Tuning Addict
    10,802
    There are stock L59 files in the repository. -> https://www.hptuners.com/my-account/tunerepository/
    Unfortunately, the only way to know if a 5.3L file is LM7 (8th VIN 'T') or L33 ('B') or L59 ('Z') is to download and then open to check the VIN.
    Jul 2022
    7
    So do i need to pull the L59 tune and retune it to my truck for the flex fuel to work?
    Jan 2015
    Arizona
    1,165
    yes.
    you have to tell the ECM it now can use E and then you have to set it up so it can use the E
    Thast why you download a file, and use it as a compare file to make the necessary changes
    Nov 2017
    2,635
    yes.
    By this he doesn't mean write the L59 tune to your ECM, he means modify your existing tune to the appropriate setting from the L59 tune. At least I think that is what they are saying.
    Jan 2014
    SoCal
    1,846
    Ask and you shall receive. Two different years, same "Z" engine, different OS's yet no differences between the two using compare.
    04 Tahoe 5.3 Flex 16492813895.hpt
    2005 Avalanche Flex Fuel.hpt
    May 2014
    USA
    624
    hptuners lacks proper definitions to enable FF on a non FF car, at least on this OS.
    Did you try the file I posted?
    Jul 2022
    7
    Quote Originally Posted by aaronc7 View Post
    No. Im gonna try that first before i go the other route. Just wanted some options.
    Aug 2006
    5BA8
    5,289
    With a name like pudman, I'd never shake hands LOL
    EFI specialist
    email=[email protected]
    Jul 2022
    7
    try this one
    IT WORKED! Thanks man for taking the time to adjust that. THANK YOU!!
    May 2014
    USA
    624
    excellent, glad it worked! Let me know if you run into any FF type of issues, but everything looked good from what I could tell.
    Jul 2022
    7
    Hey man sent you a DM.
    Sep 2012
    CA
    51
    Does anyone have a FF enabled tune for Fbody OS w/ a manual transmission?
    Aug 2024
    48
    just wanna say as a side note, blind squirrel your posts are an absolute lifesaver. so much knowledge! keep it up man you're greatly appreciated
