Results 1 to 5 of 5
Thread: Trans tune need help!!
    Nov 2024
    4
    I am trying to get my Speedo correct and my trans to shift correctly but I?m not quite sure what to do I need the trans rev per mile and the vss pulse per mile. Any help is appreciated. It?s a 1996 obs with a 5.3 and a 4l60 it has 3.42 gears and tire size is 275/45r20
    Tuning Addict
    10,887
    Quote Originally Posted by Lsobs_1996 View Post
    If you can't figure it out, and you're able to see what's currently in the file, how is anybody else that can't see what is in the file (because you didn't post anything to look at other than a story) supposed to tell you which things need to be changed and by how much?
    Nov 2024
    4
    Sorry still trying to figure the website out only just made an account yesterday but I got the trans fixed and the speed sensor corrected but my cluster is still off so trying to figure that out now
    Nov 2006
    North Carolina
    4,874
    There is a gear/Tire calculator in HPtuners that does a reasonable job. Under file - edit.
    Nov 2024
    4
    My speed sensor is correct now with gps but cluster is 10mph fast is there anyway I can fix that or do I just have to pull the needle off and move it
