Page 1 of 3 123 LastLast
Results 1 to 20 of 47
Thread: won't stay running
    Aug 2024
    Texas
    174
    won't stay running
    i just added a new 1000cc fuel injectors, fuel regulator, and 2 bar map sensor. I also moved the iat sensor to the intake. I'm using the default settings in the 2 bar os map sensor settings which may be the issue.
    Jan 2015
    Arizona
    1,293
    Quote Originally Posted by smasher View Post
    i just added a new 1000cc fuel injectors,.
    what injectors and did they come with GM data that you used to modify the tune?
    Nov 2017
    2,802
    Log?
    Injector part number?
    Injector data?
    Map part number?
    Details of what you are working on?
    Fuel pressure?
    Fuel system setup?
    etc
    etc
    etc
    Aug 2024
    Texas
    174
    GM 19418808 map sensor
    1000cc (100 lbs/hr at OE 58 PSI fuel pressure) FIC Fuel Injector Clinic Injector IS304-1000H
    58psi constant
    starts with gas pedal applied but won't stay running for a log
    408 tune by sirius just made some modifications to it.
    Nov 2017
    2,802
    Log without it running can say a lot. A log that you can keep running will say even more.
    Aug 2024
    Texas
    174
    runs really rich
    14,067
    MAP sensor is pegged at 105kpa, that is a big problem.
    Also you'll need to switch to the 2 bar MAP channel to log it correctly.
    Aug 2024
    Texas
    174
    can i put the 1 bar back in there to see if that will solve it without issues?
    Tuning Addict
    10,887
    19418808 is a 1 bar sensor. Linear/offset of 94.43/10.33.
    Aug 2024
    Texas
    174
    that's strange I was told if it has 2 rows of numbers it is a 2 bar. ill order this one 19418810 then it says 2 bar. thanks for your help
    Tuning Addict
    10,887
    Never heard of that, sounds like bullshit.
    Cobalt SS MAP sensor is 1 bar. Cobalt SS baro sensor is 2 bar. P/N 12615136 or equivalent.
    https://www.rockauto.com/en/moreinfo.php?pk=10061124
    Banned
    Mar 2022
    Indiana
    4,289
    Why would a baro be 2 bar? The cobalt ss map sensor is 2 bar, 90423637, and it's also a TMAP. Take advantage of that.
    Banned
    Mar 2022
    Indiana
    4,289
    Wait a minute. I thought I already gave you good options for 2 bar maps? TMAP or IAT/MAP separate. With separate IAT get a 12615136. Linear/offset is 200/8.
    Fuel pressure is setup for non-referenced. Is that the reg configuration?
    Set Fuel>Transient>Min Fuel Mg to 0.005.
    Aug 2024
    Texas
    174
    I bought an adapter to use the tmap but was concerned it leak, the adapter wasn?t really well made. I then thought about drilling it but then I was concerned with the way the oring was setup on the tmap that it would leak so I just dropped in a 1 bar I had thought was 2 bar and drilled out the egr spot next to the map sensor for the iat sensor. Ill adjust those configs and get a that map sensor. will the 19418810 not work or is the other just more commonly reliable? not sure if the injector info is correct I just plugged in what they had onsite. they didn't send any info with the injectors.
    https://fuelinjectorclinic.com/GM-DATA/HP-TUNERS-1000
    Aug 2006
    5BA8
    5,483
    Squirrel is right. This is the sensor you want. Plug and play. No adapters, no cutting and splicing.
    That's what it is.
    EFI specialist
    email=[email protected]
    Tuning Addict
    10,887
    2005-2007 Cobalt SS (the supercharged one, not the turbo)
    Attachment 154335
    Nov 2017
    2,802
    Attachment 154335
    And also not the NA 2.4L which GM also called SS for some years.
    Aug 2006
    5BA8
    5,483
    That's the same sensor PN we been using for nearly 20 years now.
    EFI specialist
    Nov 2006
    North Carolina
    4,872
    We have a handy listing of a bunch of map sensors with offsets/etc
    https://www.pcmofnc.com/wp-content/u...AP2-scaled.jpg
    Aug 2024
    Texas
    174
    12615136 ,and 19418810 are the same correct? It’s on the same chart labeled under 2 bar. It says 19418810 is the updated version of 12615136.
